Results 1 to 10 of 14
April 27th, 2004 11:12 PM #1
pwede ba naman mamatayan ang car na automatic ang transmission?? akala ko dati impossible!! pero pwede pala!! kainis yun mazda 323 ko nagfluctuate nanaman yun rpm... dati hindi ito ganito pero for the past two years naging ganito... tapos minsan namamatayan pa ako pagnakahinto... lately kahit umaandar biglang mamatay... nawawalan ng kuryente... gusye help naman ano kaya problem nito?
April 28th, 2004 11:14 AM #3
thanks... paano ko malalaman kung contaminated yun fuel? paano palinis?
April 28th, 2004 01:20 PM #4
Drain all your fuel and check visually, ginagawa ito sa mga gas stations kung san maraming lalagyan para sa aalisin na fuel sa tanke, which is 45 liters or more when full.
April 28th, 2004 05:12 PM #5
i agree.. possible clogged fuel filter, fuel lines.. not enough gas is getting to your engine... possible din na bad batch of fuel.. for the past 2 years ba you've been getting fuel in only one station??.. if so.. change station.. if not.. then you might have some water contamination inside your tank.. and kahit san san ka magpakarga.. kung nandun sa tanke mo yun... talagang mangyayari yan... EFI ba yan??.. baka yung fuel pump mo ang may topak...
check your fuel system... get a tune up.. possible din na your idle is not up to spec and that you have a problem with idling.. causing your car to die down.. pag nde ka naka-ac nangyayari ba yan?.. what are the circumstances na namamatay ang makina?
April 28th, 2004 05:28 PM #6
Clogged fuel filter din ang problema ko sa Benz dati. Madumi lang pala yung tank. Afterwards, ok na.
April 28th, 2004 10:19 PM #8
pag-naka a/c namamatayan pagpinatay tumataas yun idling... magkano magpalinis ng fuel system? saan maganda?
April 28th, 2004 10:27 PM #9
Idle up vaccum may problem kung on ang aircon at namamatay. May tagas ang linya ng hangin papasok dun. Or if your vehicle has computer chip, merong isang part yung ECU yata yun, di na gumagana.
April 30th, 2004 09:52 AM #10
Maraming pwedeng factors on that. I've also experienced that once on our old 323 before. Same thing happened recently with our Cefiro (which i think was because of a bad load of gas).
Start with the basics. If you have not changed your fuel filter, change it and check your spark plugs/ignition system as well. Then move on to the other possible parts (Vacuum lines, sensors, etc)...
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
