Results 1 to 13 of 13
    Dec 2007
    anu disadvantages & advantages ng slotted rotor disc ventilated with holes?
    mura kaya ito? binebenta sakin ng P5400 1pair na
    sabi nila mabilis daw mabiyak to pag hi-speed driver ka pro pag normal eh ok lang
    advice naman ok ba ganito or stock nalang ako
    mukhang made in taiwan to
    Jun 2006
    bakit naman bibilis mabiyak? Most high-performance cars use slotted-drilled discs.
    The slots that we see on these types of rotors are actually machined in there to help remove dust and water found in racing conditions. These are not commonly found in regular cars because they tend to be harsh on the brake pads which wears them off quicker.
    As far as I know, cracks occur on the rotor when it is of poor build quality. Remember, brakes work hard too when the car is subjected to extreme driving.
    The advantage of slotted and drilled rotors is that it prevents the build up of water when driving in wet conditions, a plus in safety factor.
    where would the water come from in racing conditions?
    When it rains during a race. They only change the tires during pitstop but never the rotor disc.
    Quote Originally Posted by forcemajeure View Post
    Only stock brake rotors that are later drilled/milled to provide the holes/slots can be considered dangerous because it might shatter due to the added stress of the holes/slots.
    The main purpose of the holes is to provide a way for AIR to escape and prevent the brake pads from floating on a layer of high temp gasses escaping from the brake pads. The slots, on the other hand, provide a mechanism to clean the surface of the brakepad.
    I'd suggest a slotted disc but not a cross drilled disc. The slots allow gas build up between the pad and the disc from accumulating without the risk of cracking that cross drilled rotor have and also allows cooling of the disc. If cross drilled rotors aren't done right they crack during use from heat and pressure applied by the pads. Disadvantages? I can't think of any for slotted disc other than AFAIK you can't resurface it because of the slots. I use a Power Slot disc for my car and it's made by Brembo combined with EBC Red Stuff heavy duty ceramic pads.
    Price...hehehe
    Aug 2004
    +1 kay redorange.
    Not all cross-drilled discs crack, but brake rotors get hot in daily use, then cold, then hot. This is because of the nature of traffic. You heat the brakes up when you hit traffic, then they cool down when you get out of it. Unlike the race track where they start cold, get hot, and stay hot throughout the race.
    This continuous heat-cycling eventually leads to warping in stock rotors. On cross-drilled rotors, it can lead to cracks... most famously on new Corvettes, which come with cross-drilled rotors.
    While a lot of people have no problem with cross-drilled rotors, there's still a chance of cracking, especially if you're not sure of the construction or brand of the rotor you're buying. If i were getting cheap aftermarket rotors, I'd go for slotted ones instead. They're still "pogi" points, anyway.
    Dec 2007
    salamat sa mga replies...
    eto pa question ko mga masters...
    yung price nya na P5400 mahal ba? or tama lang?
    baka bumili kasi ako nito pagdating ng tamang panahon eh..
    Dec 2007
    diko din pala sure if made in taiwan, or made in japan to
    wlang nakalagay eh...pro para sakin ok na ok sya kc dinaman ako umaabot ng 100kph lagi eh...
    pro 60kph to 80kph lang ako and slow driver ako...
    ok yung safety factor pag na daan ako sa may basa or baha mabilis matutuyo rotors ko pag slotted-drilled rotors gamit ko...
    sana mura na ang P5400?
    They are also more likely to crack because as Nicky posted the heat cycling of street use is more stress than keeping it hot and slowly cooling the disc. Taking hot metal and cooling it by driving through flood waters can cause metal failure/cracking/warping. If you want something similar get a slotted disc without the cross drilling and you'll find that it's also cheaper.
    Dec 2007
    waahh mali pala pag kaka intindi ko... anyway tnx...hanap ako ng slotted lang
disadvantages & advantages ng slotted rotor disc?
