Results 1 to 10 of 11
February 28th, 2005 01:17 PM #1
Sirs, here I am again...faced with another observation and seeking for your expert opinions...Is it normal for our rides not to reach its normal working temperature during night time or early morning driving? In my case, normal temperature is somewhere halfway on the dashboard panel. Kase napapansin ko na pag d umabot dun sa usual halfway temp. nya, iba ang tunog ng engine...parang bang magalas? that's the closest to how i can describe it
pero pag daytime naman, smooth naman ang tunog...i really don't know if its just me or if something's not right. by the way, temp. at night is around 1/4 on the panel pero pag natraffic it reaches the normal level naman pero pag go na, bumababa na ulit! sana naintindihan nyo! lastly, idling is just the same... around 1.1k rpm
those with isuzu rides, ganito ren ba ang rig nyo? mine's using the 4jb1t.
thanks!
February 28th, 2005 01:22 PM #2
i dont think this is normal, lalo na on a gas engine. but wats ur ride btw?
February 28th, 2005 01:25 PM #3
its a diesel pickup...like i said tumataas den naman but then not as high as day time driving...almost the same, mejo mas mababa lang ng kaunti.hmm...
February 28th, 2005 01:27 PM #4
Is your thermostat functioning well (does the engine still have the thermostat?)? It could be possible that it's not regulating the engine temperature efficiently anymore.
February 28th, 2005 01:29 PM #5
defective temp sensor, thermostat stuck in the open position most probably..just a guess.
February 28th, 2005 01:32 PM #6
san po ba nakikita ang thermostat? anyways, maybe that's the culprit...ill have it checked asap.
pero vinj, when i start it up in the a.m., pag iniwan ko naman ng mga 10-15 mins idle, tumataas naman.
March 1st, 2005 12:12 PM #7
honga, medyo abno yan. ke tag-ulan, gabi o mainit ang sikat ng araw, dapat consistent ang temperature.
March 1st, 2005 12:26 PM #8
BB is right...temp sensor yan. ganyan din akin eh, di ko pa nga napapaayos since wala naman history ng overheat oto ko kaya panatag pa loob ko.
pag may time na ko tsaka ko paayos. :D
March 1st, 2005 01:19 PM #9
so it doesn't have something to do with the engine's temp? wala ren naman kseng history of overheating kya ayoko ipagalaw and pag daytime, normal naman sha...
Mejo OT: do coolants really help? since napag uusapan ang temp. i don't use it kse. sabi ng mekanik ko ok daw ang coolant para d ren kalawangin yung radiator. is there any disadvantage?
March 1st, 2005 02:33 PM #10
Originally Posted by BeetOls
VinFast VF 3
