Results 1 to 10 of 10
- Jan 2005
- 157
February 24th, 2008 01:55 AM #1Happened again for the second time in 4 days.Kala ko baradong fuel filter lang dahil after linisan bumalik na sa normal, kinabukasan nagpa tune up,change oil and palit ng bagong fuel filter.Sat to Monday ok naman takbo ng sasakyan until last night pababa yung oto galing ng Underpass ng Cubao.
Bigla nanaman kumadyot kadyot yung oto nung nagshift ako and when I'm stepping on the gas pedal parang sinasakal na ayaw mag respond although umaandar parang kinakapos dahil hindi nagaacelerate.
Inisip ko hindi naman siguro electrical nagsosounds ako with Headlights/AC ;
Ok naman daihil di naman ng ngdidimm yung lights naparang naghihingalo yung electrricity,tama ba ?BigBody 2E Engine ang oto.
Ang kinabit ko lang dun yung Voltage Stabilizer mga 1 week na.
February 24th, 2008 02:50 AM #2
- Jan 2005
- 157
February 24th, 2008 08:27 AM #3hindi EFI sir.
Btw, thrice nangyari sa kin to in one week so siguro out of the picture na yung may bumara.
List ng mga chineck:
a.Fuel Filter
b.Tune Up
c.Change oil
d.Carb
e.Gasolina
-wala namang halong tubig
-malakas ang pasok
February 24th, 2008 03:31 PM #4
oh, I see. Carb pala ang 2E mo, well all I can think now is that if the Timing is out of Adjustment, or you have a bad Carburator. anywayz, matapang ba ang amoy ng exhaust?? nangangamoy gasolina ba lagi?? also, na check niyo ba ng mabuti ang Distributor, Cap & Rotor??
aite, peace.
- Feb 2008
- 2
February 28th, 2008 06:17 AM #5mga sir i do have the same problem....
bago rin lahat... got my carburator overhauled.... new sparkplugs.... new oil.... new contact point...
pero pag mag rerev ako putol putol... palyado....
at first i thought it was the fuel filter then fuel pump... pero nung nabasa ko to parehas na parehas kame ng prob...
12r pala ang makina ko...
bago rin ang fuel filter ko...
i want advice po bago ko paayos para alam ko din po ang sistema...
thanks in advance....
February 28th, 2008 10:05 AM #7
Got same problem with our old 12r engine. What we did was replace the busted ignition coil. Also, check the electricals, baka terminals or battery contacts are loose.
- Feb 2008
- 2
February 29th, 2008 01:22 AM #960 pesos lang bili ko sa filter ko...
fuel pump.... di pa ko nakakabile... pero ang kanbas ko 950...
may nakapagsabe din saken baka daw yung fuel pump ko from rear... i mean yung galing sa tanke ng gaso... pero icheked mine nasa ilalim sya so hirap ko masilip kung busted na sya...
toyota corona station wagon pala oto old school 1980 model...
add ko na rin baka sakaling makatulong....
salamat po sa reply...
February 29th, 2008 02:30 AM #10
i second the motion.
bugdabugs and mccoy26, check nyo muna hitension wires baka mahina na pasok ng current in one [or more] cable.
happened to me a few months ago. had carb overhaul, change oil + fuel filters + spark plugs, adjust ng timing, linis ng distributor... in the end yung hitension wire lang pala problema ko.
