Quote Originally Posted by redorange View Post
What could be the proble with my sister-in-law's 97 Corolla?
The car keep won't start and when they get it running it stalls gasping for air. The mechanic first said it was electrical so they changed the following so far:
Battery, ignition coil, alternator, battery wire connection, spark plug wires.
The car clicks when you turn the keys but it won't start now and she had to get pushed when it stalled on the road.
Could this be MAF sensor or a vacumm problem because it starts to gasp for air according to her before it dies? They have to step on the gas pedal to try and keep it from stalling.
Please help guys, I'm here in the US and they are asking for my assistance but I can't really do anything if I can't see what is going happening to the car. We also really need the car now since my father-in-law is in the hospital.
TIA
The car is in Sucat now any good shops around there? The only one I know of is Autotechnika near ATC if I recall correctly.
im sorry to hear about your father-in-law,anyway according to them ( your family) they have to step on the gas pedal to let the engine still running,usually maf sensor does this kind of problem,have them check its connection or clean the sensor itself with dry air spray.there are aother things that need to be checked, such as incorrect ignition wiring or faulty coil and also have them check the idle mixture (too lean or too rich),vacuum leak or low idle speed. i hope it will help them out.
