Results 1 to 10 of 10
- Jun 2004
- 1
June 9th, 2004 02:34 PM #1i owned a 99 Civic Lxi....is it advisable to rev the engine in starting the car?
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 10th, 2004 12:04 PM #3yup, when cold this is bad kasi wala pa oil sa makina.
when about to turn it off wala din naman use. kapag carb yung makina may silbi ito.
June 11th, 2004 10:34 AM #5
nope, just let it idle for a few seconds then you can drive off. gradual acceleration lang dapat, wag mabigat ang paa sa gas.
- Aug 2003
- 125
June 14th, 2004 09:49 AM #6sir speedyfix, what do u mean na kapag carbureted ang makina may silbi ang revving? when is this, on startup or pag papatayin na ang engine?
i run on carb engine, i don't rev whether on startup or shutdown. sa startup kasi one click lang kagat na.
June 14th, 2004 11:12 AM #7
Yung lumang manual na nabasa ko dati, you had to pump the gas pedal once or twice BEFORE you start the engine, para daw may gas to burn. I think this is for carb engines. Tama ba? I would assume the EFI will take care of the initial gas required to fire up the engine. Paki confirm lang po...
June 14th, 2004 07:19 PM #8
sa OLD carb engines tama yan, pump before start and rev before shut down para may fuel sa main bowl ng carb.
pero sa mga bago na engines, carb man or efi, di mo need gawin yan.
actually it is not adviseable revving up on shut down kung may catallytic converter na ang car ninyo (most new cars have). this can cause an explosion or at least a premature breakdown of the cat.
- Nov 2003
- 3,849
- Nov 2003
- 3,849
If the Chinese brands have a lot of parts in Lazada bakit ang Gen 1 Ford territory na made in china...
2024 Manila International Auto Show APRIL 4-7,...
