Results 1 to 7 of 7
    May 2013
    my car is a mitsubishi lancer glxi 1997 model. car jerks after an hour of driving as if it wants to die!! pina tune-up ko na, pinapalitan spark plugs, oil filter, fuel filter.. ganun pa din!!! at dati 11 km per liter consumption nya ng gas ngayon 8 na lang. pina check ko na kung ano ano na pinalitan nila di nila alam ano problema..
    pag na jerk sya normal naman yung oil gauge. parang nawawalan sya ng power kaya pag nag jejerk na pinapatay ko na lang aircon. or pag grabe na hinihinto ko muna sya sa gasoline station tapos yosi muna ng dalwa. after mapahinga ng konti ok na naman sya. tapos babalik ulit!!!
    kung sino man may alam ng ganitong problema paki reply na lang po wala naman akong pambili ng bagong oto kasi hehe..
    Oct 2005
    Try a higher octane fuel or have your tank drained/cleaned. HTH
    Let's wait for some of the guru's response.
    Feb 2009
    Quote Originally Posted by venom621 View Post
    have you ruled out stuck brakes?
    Boss,
    GLXI eto yung may servo, iacv or throttle valve po ba tawag dun, try mo sir palinis or diagnose baka may sirang sensor.
    Aug 2004
    Sounds a lot like ignition coil issues, if it gets better after the car cools down. Also check that the high tension wires are okay.
    May 2013
    nag search ako sa net mukhang ignition coil nga sir. pag may time ako this weekend paayos ko then ill update u guys..
    Pag jerking na, feel mo yung ignition coil kung sobrang init, if so, try mo basain isang basahan, wag pigain, tapos ipatong mo dun sa ignition coil mo para lumamig, then paandarin mo ulit and tignan mo kung wala na yung jerk. Kung nawala jerk, that means ignition coil mo nga may problema.
car jerks after an hour of driving!! need help!!
