Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Feb 2006
    mga sir
    tanong ko lnag po!yun po kc dashboard nung ride ko is medyo kupas n tska me mag flecks ng white sya cguro mga paint overspray yun!(recent washover kc)pati yung mga side panels
    tanong ko lang po is there any way n ma ibalik yung deep n kulay nung dashboard and shine (DIY po sana).try ko n rin po kc yung mga dash cleaners(ArmourAll etc .) ganun p rin e !
    or if not any shops na kayang gawin yun?
    btw ride nga po pal is 7G galant
    any help would be greatly appreciated !salamat po
    Paint strippers?
    A milder substitute could be acetone. Kaso try mo muna sa tagong part at baka lalong lumala problema, hehe.
    DIY mo muna subukan mong pahiran ng Armor All baka sakaling ma-restore pa.
    Sep 2004
    Back to Black or Tire Black (Autogard) lang yan, balik na kintab nyan
    Feb 2006
    mga sirs salamat po sa advice ,tips,
    natry ko n po yung Armorall e!kaso d p rin e!yung paint specks naman anhirap tanggalin,pero di ko po nasubok yung paint strippers bka kc lalo lumala e pero try ko rin s tagong part,
    kung s tire black nman cge po try ko rin medyo kupas n nga kc kulay nya e kaso d kya magiba kulay nun kc d b medyo gray yung kulay ng dashboard?tska d kya madamage ng tire black yun?
    anyway try ko po rin to lahat advice nyo!salamat po uli
    keep ur suggestions coming if meron pa po
    get an APC properly diluted to its proper ratio before using dressings (armor-all).
    if im not mistaken, hindi cleaner ang armor-all. also, try to get a dedicated product for your dash.
    make sure to re-wipe after applying your dressing to get a nice matte finish. greasy doesn't really work.
    Jul 2006
    There have been stories that have shown Armor All to have been resposible for cracked dashboards.
    If you want good UV protection, I'd suggest Aerospace 303 if you can get them. They're worth $12 here and even have a SPF value (40 yata?). SPF means sun protection factor, and is the same thing with the ones you see in Coppertone bottles.
    Give claybar a shot, it has effectively removed paint overspray on one of our cars when our boy did some DIY work and there was a good wind. If not, I've always had good luck with a good paint cleaner. If yours is a plastic dashboard, a plastic cleaner/restorer should also work. PlastiX comes to mind here.
    Dec 2004
    Try mo rin wipe-out...
    Sep 2006
    leatherique will solve your probelm.
    Aug 2006
    don't use armor all. trust me. just don.t
    Feb 2006
    sir m_ron
    ano po yung leatherique?brandb yun o product name mismo?saan po mabibili yun?price?
    sir torque ,
    bkit po pala ayw nyo armor all?any reasons why?
    salamat po! sa mga tips keep 'em coming
    Aug 2006
    1. because after a few months, your dashboard would feel oily.
    2. it also reflects the sun (and usually bounces off to your face while driving)
    3. for some plastics, it makes it crack. they said they changed the formula, but it still happens. some attribute it to overzealous polishing > imagine your leather shoe being applied with kiwi leather wax every week <
    4. it doesn't really clean your dashboard. it just covers it with a thin film of "protectant"
    Sep 2006
    Quote Originally Posted by torque2006 View Post
    Oh shi*t! I already used ArmorAll on my dashboard! Any suggestion on how to remove it?
    May 2004
    *picard, use APC to remove/clean AALL on your dash. you can also use soft brush for thorough cleaning.
    *threx, as suggested by some tsikoteers, try to clean your dash with APC...brush it a bit with a soft toothbrush. then apply a good dash protector (e.g. megs, moms or you can try cleanshinemaster).
    Sep 2006
    Quote Originally Posted by silhouette View Post
    Meron po na nito sa mga Ace hardware? Is this some kinda cream/lotion/or liquid spray?
    Mga sirs,
    Newbie me d2. Can APC also remove double adhesive marks left by "dashield"? I had mine removed kasi and it left a lot of adhesive marks with some residue of foam on it.
    Thanks.
    kung leatherette ang dash ninyo you can try using the "shoe colorant" - this is the colorant used by oldschool sapatero (available ito sa mga shoe supply stores in Marikina - katapat ng palengke ng marikina, yung malapit sa munisipyo ng marikina na palengke) para ibalik sa kulay ang leather or leatherette ng sapatos.
    this dye/colorant is very good. applied ito using a damp cloth.
    Quote Originally Posted by evanz10 View Post
    Mga sirs,
    Thanks.
    same as mine. Any suggestions guys?
    Sep 2004
    WD-40 lang katapat nyan, plus soap and toothbrush.
    I don't know about the others, but Armor All works for me. The dashboard on my 1996 Sentra has been protected by Armor-All since the day I bought it, and my dash looks like new. No cracks or discoloration whatsoever. Actually, I get a lot of praise pa nga, kasi pati yung door sidings ko, parang bago, protected din by Armor All.
    Yung 1980 Galant ko din nun (nabenta na), makintab at maganda rin ang dash. Armor All din ang gamit ko.
    Quote Originally Posted by Galactus View Post
    same here. i just thoroughly wipe the dash down w/ tissue to absorb and remove the somewhat "oily" finish and to dampen the extra sheen after application.
    btw, i've been also applying it to the fd w/ relatively good results. ang lapad kasi ng windshield at dash niya kaya kailangan talaga ng protection
Dashboard Rejuvenation?
