Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
    May 2016
    #21
    IMO, as I mentioned. reasonable ang 45k. I think hindi bababa ng 30K ang proper paint job.
    granting na hindi sila gagamit ng mamahaling paint, medyo matrabaho ayusin ang bubong, especially since mahirap alignment nyan.
    yes po. ang only worry ko lang po is nasama po ung pillars. sinuggest ko ung roof cut sakanila, tho sabi nung shop, hindi nya magguarantee kung hindi magrrust kasi iba parin daw ung dating pagkaweld ng factory.. kaya di ko nalang pinush ung roof cut w pillars na restoration kasi hirap din iakyat ung roof cut galing manila to baguio pa. thankyou!
    Jul 2013
    #22
    Quote Originally Posted by Sedanlover View Post
    agree ako dito...
    majority kasi ng local shops use Acetylene welding... in 2 years time kakalawangin din kasi niluto nila yung yero.
    #23
    agree ako dito...
    it would depend on the skill of the latero, the skill of the metal prepare-r, as well as the skill of the pintor.
    i have seen several weld jobs,
    after many years,
    wala pa ring kalawang sa winelding na parte.
    May 2016
    #24
    after many years,
    Ito po update doon sa repair.
    Oct. 11 po ung pinunta ko po sakanila ung car.
    hopefully mahabol nila pati ung bend sa pillar
    #25
    didn't they ask you to get a replacement windshield?
    i imagine, they use it as template when shaping the frame.
    May 2016
    #26
    windshield po or ung backglass?
    meron na pong backglass. un po ginawa nilang guide para maalign po.
    May 2016
    #27
    ito po update. medyo hindi ko pa po ma appreciate since hindi pa tlga sya tapos hehe.
    ung sa roof po, naacept ko na hindi na sya tlga mauunat unlike pag roofcut tlga ang ginawa.
    pero ang worry ko lang po tlga if worth it pa kaya ang repair or maganda ibenta nlng din hmm
    Attached Thumbnails Attached Thumbnails wreck.jpg   wreck1.jpg   wreck2.jpg   wreck3.jpg
    #28
    as long as the metal doesn't rust, the glass don't break, and the seal don't leak...
    the magic of putty filler.
    Jan 2016
    #29
    That's the problem, coz according to Neil Young, rust never sleeps [emoji16]
    #30
    turco-hin yan!
    May 2016
    #31
    sinabi din po yan ng shop owner, lalo pag wala daw pong garage na may bubong.. pero i think that applies naman kahit anong sasakyan hehehe
    May 2016
    #32
    kaya ba nila gawin in 1 month ang repair? or it needs more? thankyou!
    May 2016
    #33
    +1 on the roof cut. Re-scalped a Civic w/o welds a while back....not from collision damage but by stubborn rust. Honda used the wrong sealant on PhDM units of that era. The JDM roof had 0 corrosion & got the proper scalp-frame adhesive.
    Your pillars, repaired or transplanted, must be carefully aligned relative to doors & windshields. This will be skill-dependent. Look for a good builder.
    sir pwede po ba malaman how much ang nagastos ang labor ng roof cut?
Can it be repaired?
