Results 1 to 9 of 9
December 16th, 2007 11:00 AM #1
Guys saan ba at paano ba ito inaadjust to make shifting more responsive?
I think my FC is suffering because ung low end power ko lakas pero it doesnt downshift too often. You need to depress pedal full to downshift. Paano ba?
TIA
December 16th, 2007 11:10 AM #2
sir, anong klase kotse mo?? anywayz, I think that theres no other way to adjust an A/T.. specially if its fully Electronically Controlled (not unless you have a American Truck like Ford, Chevy, GMC.. which you can buy a programmable ECU scanner that can adjust Throttle Position and Shift Patterns on A/T transmissions).
aite, peace.
December 16th, 2007 11:15 AM #3
Boss Corolla altis eh. Parang bitin kasi ang shifting. Parang may ishishift pa siya pero sagad na ang accelerator pedal. Do you think it is the throttle cable that I should adjust?
December 16th, 2007 11:22 AM #4
December 16th, 2007 12:25 PM #5
Thanks KBR. I tried to adjust the throttle cable but failed. Mukhang sagad na yung nuts.
Tried to see if there is an adjustment in the pedal area and found out theres none. I'll try to see if i can adjust the carpeting since its the one hindering full throttle. Im just curious why this just happened now. Factory set naman lahat.
Anyway thanks again.
December 16th, 2007 03:04 PM #6
haven't seen the inside of altis A/T.
you mean you want it to shift down gear right?
if Altis A/T still use the old fashion kickdown cable (most of the time it is wrapped in orange rubber or atleast an elastic rubber). you need to fasten it tight.
sample pic from a pajero.
but I'm not sure if the Altis A/T still use the older system. baka fully electronic controlled na yan...
- Oct 2007
- 15
December 18th, 2007 12:57 AM #7Try to have the accelerator or throttle position sensor checked and adjusted. Automatic transmission usually uses the signal from this together with the speed sensor to know when to change gears. If set too low will make your engine to shift late. If set too high will make your transmission shift early. What is your ride ba? When you try to full pedal the accelerator cable your AT will kick down (usually used in overtaking).
The throttle position sensor is located where the injection pump. It moves and its position depends on the accelerator pedal. Usually three wires ito. When adjusting have a mark so you can return it to original position if no improvement. A voltage tester will be very handy in adjusting this.
Hope this helps.
- Mar 2004
- 434
December 22nd, 2007 11:16 AM #8try to adjust the cable opposite the throttle cable. i think this is the kickdown for the a/t tranny. its also attached to the throttle body same way with the trottle cable. i forgot if to loosen is to make the shifting late or the vice versa. try nyo lang.
also, not sure if the altis has this. but my crv and smx (both honda) have this.
hth.
December 23rd, 2007 02:15 PM #9
loosen will make it upshift early... tighten will make it downshift early...
sometimes, you feel upshift early 'Lossen' is the best adjustment to save fuel. but one must also take note how deep are you pushing your accelerator pedal. plus too loosen will have problems uphill...
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
