Results 1 to 14 of 14
    Feb 2004
    puwede bang maglagay ng grease fittings sa bushing pin as in drill through the head and put zerk fittings and make a smaller hole through the length of the pin so as to allow the grease to come out of there?
    in other words, make the pin hollow with a smaller hole at the shaft? or better yet, may nabibili na ganyan na? TIA
    Meron naman nabibili na greasable shackle pins from Isuzu trucks, you will just have to bring your original part to get the exact measurement fit.
    Are you planning to put it on the rear pins for your Patrol?
    Feb 2004
    HI Ungas
    no, actually para sa Samurai. yung saan nakakabit yung mga shackles. durog na kasi ang mga rubber niya and was thinking of poly pero baka madurog rin lang kasi umiikot di kagaya ng sa patrol.
    Oh, sa Samurai pala, maliit ang shackle pins nyan. Pero meron nyan sa mga auto shops na greasable pins na para di ka na mahirappan pa magbutas.
    Feb 2004
    thanks Ungas may alam ka ba kung saan? I tried dito sa jp rizal sa makati eh di nila alam daw yun
    Try Izuparts in Caloocan.
    Feb 2004
    ok TY Ungas
    baka mahirapan kang makahanap niyan. maliit kasi siya compared to isuzu pins. 50 php lang ang rubber bushings kay Links.
    I was thinking of Toyota Dyna pins, may maliliit nun.
    Feb 2004
    called izuparts and they weren't very helpful
    ano kaya kung patorno ko sa machine shop and have them fit yung pang grasa and drill a small hole sa shaft?
    tapos pwede kong benta sa mga sammy owners din at cost :D
    Pwede rin! And earn in the same process. :D
    Kaso baka mas mapapamahal ka sa uri ng metal na gagamitin. If you have a good machine shop to go to, it wouldn't hurt to have it canvassed.
    Feb 2004
    o kaya kunin ko sa bushing ng samurai tapos pabutas sa machine shop and palagay ng fittings? will do the legwork next week and tell you what happened. mahal na rin kasi bakal ngayon eh.
    ilan butas kaya kailangan sa shaft mismo para doon lumabas ang grease?
    A rough estimate, 2 holes on each side.
    Feb 2004
    I found na where I can get greasable bushings!
    di ko na papagawa bili na lang ako
    check this out: http://www.rocky-road.com/zuksus.html
    Greaseable Bushing setup for entire vehicle
    Truly the ultimate in setting your entire Zuk up for a smooth free flowing ride. This top of the line bushing kit includes all bushings and greaseable bolts for the entire vehicle, front and rear on all four springs. No more rusted bolts, squeaky bushings, binding suspension parts. This kit is truly for the Samurai suspension connoisseur.
bushing pin
