Results 1 to 9 of 9
June 4th, 2006 01:10 AM #1
what a very nice timing...
on my way home tonight, twas really a good thing i let the rain subside a bit before hitting the road...and just about few minutes of driving, my driver side wiper got stucked and stopped right in the middle, the one from the passenger side collided with it and went out of position too...so i stopped, checked what happened...
i got the one on the passenger side back to work pero yung sa side ko wala na...parang free play na sha eh...ang hirap tuloy umuwi! i was thinking...may cable lang ba yon na nagcoconect sa kanila? simple lang ba i diy yon by just unscrewing the plastic cover just right below the windshield?
TIA
- Jun 2005
- 215
June 4th, 2006 01:26 AM #2Originally Posted by BeetOls
http://auto.howstuffworks.com/wiper1.htm
June 4th, 2006 01:39 AM #3
thanks! the link won't open...i'll try to browse the site...i used to be a fan of that site.
June 5th, 2006 09:03 AM #4
Ok lang yan Beetols. Sanay ka naman mangapa sa dilim eh. haha.
Seriously, good thing nothing happened to you. Pacheck mo nalang sa suking mekaniko.
June 5th, 2006 09:06 AM #5Originally Posted by BeetOls
most probably worn out wiper bushings. mura lang yan bro. definitely hindi wiper motor yan kasi buhay pa yung kabila mo eh.
- Feb 2006
- 43
June 5th, 2006 06:09 PM #6Originally Posted by happy_gilmore
June 5th, 2006 08:15 PM #7
just fiddled with it this morning before going to work...yup..yung linkage nga pero yung nakakabit dun sa passenger side na wiper...i don't know what used to keep it in contact kase wala naman screw (maybe becaues its a moving part), i just pushed the linkage dun sa may pwetan ng other wiper tapos ok na pero pag na lubak eh siguradong tanggal ulit. medyo mahirap gawan ng support dun sa mismong joint kase nakapaloob na sha dun sa drainage and the only thing visible is the shaft/arm going the other wiper...so tinalian ko nalang muna at least para di bumagsak and will have it checked pag natanggal ulit! hehehe...
May 28th, 2007 04:52 PM #9
hi beetols!you will need to access the wiper link (usually entails removing the cowl grill )to check if the free playing wiper arm popped out of the link. for this you'll just have to pop it back in. otherwise, you may need to replace the whole link if there's extensive damage (around 800 pesos). check if the wiper arm shaft broke from the lock nut, apply steel epoxy as a temporary relief until it breaks down for good.good luck, you can do it!
Xiaomi E-Car
