Results 1 to 5 of 5
January 26th, 2008 10:48 AM #1
Pls help me find what's causing this:
Whenever I travel on well paved roads at low to moderate speed, i notice this slight bouncing feeling on my steering wheel. This sensation is more pronounced when I step on the brakes.Thanks in advance.
January 26th, 2008 11:26 AM #2
sir, does the steering wheel feel loose?? or the whole car is bouncing??. anywayz, if the steering wheel feels loose then you might have a worn steering rack. and if the car feels loose or if it has a wavy ride (ma-alon) then you might have a busted shock absober(s).
aite, peace.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 27th, 2008 09:44 AM #3it might be easier if you show a mechanic what you feel is wrong. that way he can diagnose the problem there and then.
January 27th, 2008 03:53 PM #4
No sir, the steering is ok, only, I can feel that little bouncy ride and it's also felt on the steering wheel itself. I suspect my tires because i rotated them just recently. Though im not sure about it. Maybe some balancing is needed. Thanks for the reply.Ditto for sir speedyfix.
January 27th, 2008 06:05 PM #5
I see, well if its not "bouncy" and if you think you need a Wheel Balancing then you should feel a vibration on the steering wheel.. specially if your driving at 55-65 MPH (damn.. I forgot how it is in KPH!!.. *90-100 KPH???*).
anywayz, you can check your tire wear & pressure too.. since it might be low (and the treads might be un-even), and youll never know!!
aite, peace.
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
