lately dami kong nakikitang mga dedicated shops for hydraulic hoses. May nakasubok na ba sa inyo nito? are they at par with lets say OEM hoses?
nakasubok na ako bumili sa ganun... kumpleto sila sa mga hose... then pwede ring ipa fabricate ang fittings... yung binili ko ay yung pang fuel
How about for hoses like PS and cooling systems?Medyo sensitive yung PS hoses (the diameter and length have to be similar to OEM spec).
forgot to mention. pang power steering . yung high-pressure.
pang fittings walang problema. dami nilang choices. concerned ako sa quality ng pagcrimp nila ng hoses. no choice din ako eh. OEM korean-made hydraulic hoses (its on my carnival ngapala) tend to leak over time![]()
Tried ko na PS hose ko... What happend is dinala ko sa kanila yung sirang hose para sa Length and Fitting. Ok naman kaso lang minsan may Ugong pag nag tuturn... But worth it naman kasi Sobrang mahal ng OEM
I always use custom made hydraulic hoses in all our vehicles when it comes time to replace the hoses.
OEM is too damn expensive.
Plus, with custom hoses, you can choose what hose type to put in. I always use high pressure hoses with metal reinforcement. Same one used in heavy equipments for construction and industrial use.
On the last hose I had made, Mang Mario used Bridgestone (yep, the tire guys) hose then just had the hydraulic shop press the end fittings.
Ayos!
The ugong may be because of a difference in the inner diameter or even the length of the hose from OEM spec probably.
Where do you guys go to BTW?I havent tried any of those shops yet.
the name of the shop thats near to our place is muti-flex. (pasig area) thanks for the inputs tsikoteers.
OTEP,
is that the steel braided hose that is used for brake lines? thats not the same mang mario a/c specialist isn't he :D
Iba ang steel reinforced sa stainless steel braided brake lines. The hoses I use have the metal inside the rubber hoses (for protection). Check out the hoses used on heavy construction equipment.Originally Posted by benchph1
Yup, sa aircon shop. Pero pinabili din niya sa labas kasi wala naman silang facilities for pressing.
had my hi-ace's power steering hose changed last year due to leaks... 10 years old na kasi yung oto... asked my kumpare(who own's an auto supply) how much yung orig hose... ang sagot ba naman eh..."pre di pang benta yung presyo... pa press na lang natin... may U.S. hose dito na reinforced with metal". ayun total cost 2500, including labor ng pagtanggal at kabit ng steering hose, labor sa pa press ng hose, steering fluid, at yung US hose mga 1.5 meters ginamit sa hi-ace. :jump2: still works with no problem... parang alang nangyari
yeah, just be sure you get the corect length and diameter for the hose. pati fittings tama dapat or else uugong ng uugong yan when you move it
ABC hose 1st ave. cor Rizal Ave. Caloocan City. Made to order industrial hoses.
magatatanong din po ako:
wala po ako dyan sa Maynila, nandito po ako sa kabundukan ng Baguio (safe na from meningo) at kung ako po ay maghahanap ng shop na maaaring makagawa ng mga hydraulic hose na iyan to replace OEM:
-ano po exactly ang hahanapin ko na type ng hose? (dadalhin ko siguro yung papalitan at humanap ng pinakamalapit na maaring maging kapalit OR ano po ba ang mga characteristics ng replacement ang dapat na pagtuunan ng pansin to make it as good as the original or probably even better?)
-aon pong klase ng shop maaring makakuha nung mga fittings at saan ito dadalhin for fitting/placement?
(sencia na po kung eengot-engot ang tanong....nais lang pong matuto)
