Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Oct 2004
    My BMW 320i E36 body has been in the casa for more than a week now, it was supposed to be just a simple alignment problem....pagkatapos nila i-align (their equipment says that its already aligned kumbaga "0" na daw siya) and did a test drive, di nagbago ang alingment and my car was still swerving to the right....so they checked everything again "daw" (sa tagal nila eh duda na ako eh) from tie-rod to steering wheel, shocks, wheels, rack and pinion etc. etc. wala daw silang mahanap na problem...pero bakit siya nagswe-swerve pa rin? First time daw nagyari sa kanila ito....
    They told me to give them more time to check the car out para ma-pinpoint ang problema...right now, gulong gulo na ako...di ko alam kung ano gagawin dahil parang walang alam ang mga tao sa casa....
    Guys please help naman, maybe you can suggest something that they should inspect na baka nagcau-cause ng problem na ito...or maybe some of you guys have had this same experience and were able to solve the problem, please share your solution...guys please, I really need some advice....Thanks!
    Never had that problem with my previous 2-door E36 (or E46). Might be your rack and pinion or maybe just your wheels are not straight.
    Apr 2004
    car ko naman mazda 323, tapos nagswerve sa left... inayos na ng goodyear servitek, pero parang nag-swerve naman sa right pagchinecheck ayos naman... dahil daw ata kasi tabingi ang kalsada natin diba, para iwas baha...
    Thats funny..I think you should go back to that shop and have them check again. Anyway, about the E36, in stock, the steering is pretty tight (compared to american or jap car) so i dont think it should swerve in a normal average road.
    Check the tires baka yun yung culprit mismo. probably mali na yung kain ng tires nung di sya aligned noon
    Oct 2004
    They checked na daw yung tires nag rotate pa nga sila konti lang yung na bawas na swerve nung nagrotate sila, baka kaya 4 tires yung may problem?
    Jun 2004
    Maybe something to do with the brakes? brakes on one side or corner slightly slowing the car down perhaps? its a longshot though...
    I did experience this before on our car, but the problem is now gone, only thing that changed were the two rear tires.
    Have you tried inverting the tires on the rim? Did you check also if any of the rims are hotter than the other (indicating stuck-up brakes)? How about the caster?
    Yeah! Its really frustrating if the CASA mechanics can't even size-up the problem! Having owned two Bimmers in the past, I stopped going to the CASA since two years ago. Most of the BMW Club members also have their bimmers repaired outside the CASA. Believe you me, the BMW CASA mechanics don't know crap about gut-feel diagnostics and solely rely on computer scanning techniques.
    Here are some of the shops patronized by the BMW Club members:
    1) AUTOVEC owned by Werner Reimer - located at E.Rodriguez Blvd Q.C. - call 7262978 (btw, Werner is a member of the club)
    2) ERL Motorwerx - look for Ernie Lorenzo - located at C. Benitez St. Horseshoe Drive, Quezon City - call 413-3911 (Ernie took care of my E30M3 when I still had it)
    3) DTM Performance - look for Tommy Teng - they especialize in suspension problems and boasts of state-of-the-art suspension diagnostic equipment. They're located at Commonwealth Avenue. Don't have the number though. (Tommy is also a member of the club)
    Mar 2003
    Quote Originally Posted by woodfire
    Dindo, Tommy Teng? di ba sila ung nasa Caltex (e. rod)? lumipat na ba sila?
    Oct 2004
    Thanks Woodfire, I called up AutoVec and ERL, sino mas okay puntahan muna with the problem I have? AutoVec or ERL? Thanks again!!
    ...3) DTM Performance - look for Tommy Teng - they especialize in suspension problems and boasts of state-of-the-art suspension diagnostic equipment. They're located at Commonwealth Avenue. Don't have the number though. (Tommy is also a member of the club)
    I believe Tommy's new shop in Fairview is named Autotechnika. They still have the Caltex E. Rod branch, but all automotive services will be done in the new shop. Btw, months from now, a new branch will open up in Fort area.
    I'm pretty sure they can do the job well, since johnqpublic318 who also happens to post here works there too.
    dati nangyari sa itlog lancer ko yan.. the problem is the mags.. may bengkong..
    Feb 2005
    Baka naman yun threading ng gulong mo di na panta? Sometimes nasa gulong yung diffect eh. Sa Benz ko parang ganun din nangyari. Palit ako ng 2 bagong goma. Lagay ko yun luma sa likod. Try to check yun tires mo.
    Yes, bukas pa yung nasa E. Rodriguez.
    However, they have a brand new shop sa Commonwealth going to Fairview that specializes in suspension diagnostics and repair.
    Oct 2004
    Thanks guys, How about Basics sa Libis? recommended ba yon? I'll give the CASA guys until friday, kung wala pa rin I'll pull it out tapos I'll try those shops that you recommended....Papano pala yon malamang they will charge me for the alignment cost, whould I pay for it? parang ayaw ko kasi di naman nila na-align eh? pero sasabihin nila na inalign naman nila pero di doon ang problema so I Should pay them....hay hirap!
    Oct 2004
    What the website of BMW club Phil.? tried to access it parang di gumagana? thanks
    Try Autovec since they only specialize in bimmers. Tell Werner Reimer that Dindo Velasquez referred you.
    Oct 2004
    Thanks Woodfire! I'll do that
    Oct 2004
    Thanks Ungas, ngayon dami na akong pupuntahan di na ako masyadong desperado and hopeless!! hehehehe
BMW alignment problem, CASA does not have a clue what's wrong...pls. help!
