ask ko lang mga gurus...pag tune-up ba ano ginagawa???palit lang talaga spark plugs???o meron pa ibang ginagawa???
Usually palit spark plugs, adjust timing, palit ng contact point/condenser (kung hindi EFI), adjust valve gaps.
Yung ibang engine hindi na nag aadjust ng gaps ng valves kasi hydraulic type na yung adjustment. Not too familiar sa mga newer models ng engine pero these are the usual work done.
kung sa honda casa kayo pa-tune or PMS, meron silang list na ginawa sa car nyo.. kasama sa standard PMS like check the fluids, battery, rotate the tires etc... tapos meron silang recommendation kung ano ang mga kailangang ayusin sa susunod na PMS mo.
replace/adjust if necessary
~check spark plug
~check oil
~Check fuel/air filter
~check valve clearance
~check Timing
~check belts
~check distributor condeser,contact point (sa old engine )
97 honda cicic lxi ung car ko..so ano yung mga dapat gawin???mahal kasi sa casa eh...
as said, depende sa KM reading.
taga talaga presyo sa casa kaya try mo dalhin na lang sa labas. same thing at a fraction of the cost.
kay speedyfix, sa santolan, kayang-kaya yan. member pa ng tsikotOriginally Posted by vanleano
yun na nga eh...kay speedyfix ok sana...pero ang layo eh..south area ako eh...sa south ba wala magandang shop tulad ni speedyfix???
hmmm. kung taga south ka, dun mo dalahin sa minerva tires alabang. tried their tune-up services once. medyo pricey nga lang, but they did a satisfactory job.
and afaik, tune-up consists of:
a. change oil
b. change oil filter
c. change spark plugs
d. change/clean air filter
e. change fuel filter
f. adjust timing
suggestion though... gas stations offer change oil/tune-up packages.. why not try their services?
personally, i am having my tune-ups every 10000 kms at shell las pinas lang. at 5000 kms, change oil/filter lang.
thanks happy gilmore..magkano sa minerva???sa shell magkano din???sa prens ba ok din??sabi nila ok din daw dun eh..layo kasi ni speedyfix...lagay ka ng branch dito speedyfix!!hehehehe
minerva, medyo mataas labor nila eh. i think 300 for the oil change, and 400 for the spark plugs and timing.
sa shell, inaabot ako ng 2200, all in, including oil (semi-synth), oil filter, spark plugs, timing and some small activities like changing the fuel filter and air cleaner (which i can actually do myself).
yup, prens is ok. kaya lang minsan ang daming tao dun eh. wala kang maparadahan. ang hirap pang lumabas.
haha! you should be safe naman with one of those shops. i know hongly does good work in the south if you're in that area.
uhm, dinala ko oto ko sa honda spc for its regular maintenance check-up 70,000km, costs me 4,100 petot, bale change oil lng nmn ginawa, its still on warranty, sobrang talaga ko namahalan, naisip ko kung ano pa silbi nung warranty booklet, ganun ba talaga? 2nd owner na kase ko nung oto at 1st ko dinala sa honda service center
tisk tisk tisk
fully synthetic oil ata ginagamit sa casa eh. kaya medyo mahal. tapos, palit spark plugs yan. considering casa yan, doble price nyan kesa sa bibili ka. tapos labor, which could also be double than the cost if done outside.Originally Posted by mudspit
imho. 70000 kms na eh. siguro pwede na yan sa labas.
...try mo rin sa MAC-R express lube sa alabang motortown.Originally Posted by vanleano
Originally Posted by baiskee
labor pa lang yan? eh pano kung petiks yung gumagawa at inabot ka ng half day?
