Results 1 to 10 of 12
August 23rd, 2006 01:18 PM #1
hi peeps! question lang, ano ba pros and cons ng spray and ng patong = fiber glass right? friend ko kasi patong ginamit. someone told me ung patong me mga gaps daw un sa loob pinapasok ng water at sa long run baka mag karon ng rust etc. about sa spray naman they told me pinaka safe daw pero minsan nababakbak daw ung paint pag tumagal? so any pickup owners here have expirience in both pls help me choose the best? thanks in advance!
August 23rd, 2006 01:25 PM #2
Drop in bedliners from reputable manufacturers (e.g. Carryboy) are usually made of plastic.
Drop in has the advantage of preserving your original paint. However, water can get trapped between the drop-in liner and the pick-up bed. This can lead to rust. Not always, but it can.
Spray-on bedliners are applied by first scuffing (ginagasgas) the original paint of your bed. Then they spray it on. 'Nagbabakbak' depends on how good the prep was done and what kinds of stuff you carry on your beds. Spray on liners can sometimes handle corrosive liquids (e.g. acids) even better than drop-ins.
August 23rd, 2006 01:33 PM #3
Water may get stuck in between if you use a drop in bedliner. Baka mabutas or mag-crack ang plastic and di mo ma-notice, umpisa ng kalawang yan. Although maganda syang tingnan.
August 23rd, 2006 01:39 PM #4
had our L-200 sprayed with this. makapal ang nilagay and it has to be roughed up pretty badly para mabakbak.
generally, i'd opt for this.
August 23rd, 2006 01:53 PM #5
sa dmax namin, yung fiberglass ang gamit namin. ginagawa namin, from time-to-time check na lang. saka may drain naman yung bed kaya ok lang...
August 23rd, 2006 06:30 PM #6
so alin sa dalawa the best? yeah me point ka ian_rex pede naman patangal time to time dba? i think 30 min lang ata mag tangal? para check for corosion etc. drop in liner mga ilang yrs kaya yan bago magkaron ng problems pag nde chinecheck?
August 23rd, 2006 09:58 PM #7
I still prefer spray on.
May ibang drop-in na lumulutong sa katagalan and nagkakaron ng cracks or napupunit if you accidentally hit/slide something sharp on it.
Drop-in kahit magkaimperfection kaya niya itago. O kaya bili kang lata ng Pylox, iretoke mo. hehehe.
- Oct 2005
- 147
August 23rd, 2006 10:55 PM #8puwede siguro pa rust proof bago ilagay yung drop in. pero baka mapamahal ka pa kung ganun.
- Jun 2005
- 215
August 23rd, 2006 11:07 PM #9My truck came with bedliner as standard, and have it for about few months. It was good in a way because they are thicker than spray-on but they flex, and end scratching the paint on the bed, with the humidity and rain, it won't be too long before rust startingt to settle in. I got it removed and installed spray-on bed liner from Rhino Lining. So far, I'm satisfied with the results. I throw pretty much everything in the bed of my truck, my tools, rocks (pebbles), bark, mulch and occasionally my wife (just kidding). My only observation was that the color started to fade but then again its more than 5 years of abuse.
August 24th, 2006 04:25 AM #10
thanks for the comments! anyway i think il go with spray on. san shop ba magaling gumawa nito? i heard ziebart is good. btw pag nag fade na yan spray on pde ba i spray ulit yan para mag mukhang bago? or babakbakin ung dating spray then resprey again? cheers
high idle RPM at engine start
