Results 1 to 16 of 16
    Nov 2016
    hi maam /sir , i would just like to ask if ano po kaya problem sa battery ng sasakyan namen. na discharged sya then when tried the kadyot/tulak jumpstart. then na revive, so we let the car on for a little while and a bit of a stroll and let the alternator do its work for recharging. a day after nung naipark na pag start namen discharged nanaman. we have been repeating this kadyot start method but it just dies again. revived and battery and after a day discharged nanaman. what could be the main cause of this mishap. please help. any ideas, thanks
    Aug 2012
    How old is the battery?
    Sent from my D5833 using Tapatalk
    Aug 2012
    My car battery can last 2 months if car is unused. But I make sure it is 100% fully charged by using car battery charger before I travel abroad.
    Baka grounded?
    Quote Originally Posted by totoGM6 View Post
    as red asks, how old is your battery, po?
    i am very familiar with your scenario. we used to do it when we were young and poor-ish, because we had difficulty buying a brand new battery.
    in our experience, the battery was simply old and dying. it would hold a strong charge for a short time only. after a few minutes running the engine, we could actually re-start the engine using the starter. but after 30 minutes or so, there was only enough juice in her that we could still push-start the car, but not activate the starter..
    have the battery checked at the battery shop, po. sometimes, one of the six cells may be the culprit, but in our experience, once one starts to go, the rest will follow "soon".
    another possibility, is that you have a short or a big parasitic leak somewhere. an auto electrician will be able to help you here. but check out your battery, first.
    Apr 2009
    How old is your battery? and what Brand? its an indicator of your cars electrical. if you have a premium battery and its
    more than 2 years , its time to replace. but if its just 1 year maybe its your electrical system. Delikado na yan darating ang panahon kahit jumpstart hindi na yan aandar. just like dr. d said pa check sa auto electrician.
    Ilan taon na kotse and battery?
    Feb 2009
    The only batteries that don't decay are the dry charged batteries, once you activate with sulfuric acid, it slowly matures to death. Factors that accelerate death of the batteries include shock and vibration, heat and deep cycling. Otherwise if the battery dies sooner than the expected life, maybe the charging rate is insufficient in comparison to the current draw or the battery is not big enough for the vehicle
    prolonged periods of battery discharge or undercharge, also hasten battery death.
    Nov 2016
    5 years old mitsubishi adventure and an outlast brand battery 1 yr and 3 mos old. thanks for all the replies.
    feeling ko parasitic load so bka maipacheck nlg sa servitek pa multimeter/voltmeter.
    Oct 2009
    same issue..pa kadyot okey kumakarga after 2 hours ng byahe.pag napahinga ng mga ilang oras discharge nanaman.sabi palitan ng battery terminal kasi medyo maluwag daw.pinalitan ko..pero ganun parin.pina check sa battery station kung ok pa ang battery at alternator sabi ok pa naman daw..
    pero makulit ung kasama ko bumili nadaw ako ng bago.naghihinayang akong bumili kasi nga baka buo pa ung dating battery kasi nga 1 & 3 months palang.
    pero na asar talaga ako at napilitang bumili ng bago..ayun umokey naman..battery lang talaga problema...
    adventure 08 model sa akin..diesel
    Nov 2016
    Quote Originally Posted by jaypee10 View Post
    same sir. ganun din prob nung smen its all in the battery kaasar. pero buti may warranty pa.
    Bad experience with Outlast, mga 1 year lang din, tapos bumigay na. Hardstarting tapos bigla mamamatay makina at electric accessories. Putok pala ang isang plate.
    Nov 2016
    outlast brand. cant even live up to its name
    the cheapest batteries are warranted for 12 months or less. yours is probably not a cheapest battery. i think it is still under warranty. hey! you can get a brand new one, free!
    Nov 2016
    yes dr. d yun na nga ang plan the problem was the battery itself. daming d maintindihan nasa battery lang pala.
battery dies on its own
