Results 1 to 10 of 17
December 20th, 2004 03:06 PM #1
Ano kaya cause nito basa ang isang spark plug ko.
saka yung gilid gilid nang makina may mga langis, Busted na kaya yung gasket head ko.
Please advise naman mga bro. belikado kaya yun.
Thanks
December 20th, 2004 03:07 PM #2
engine wash? you went through a flood?
oil at the bottom of your valve cover? prolly the valve cover isn't fixed tightly.
December 20th, 2004 03:14 PM #3
nagpaengine wash nga ako. I dont know kung tubig sya or langis.
yah yung bottom nang valve cover madami nga syang langis sa gilid gilid.
December 20th, 2004 03:20 PM #4
ahh... nabasa nga yan sa engine wash. gamitan mo ng syringe para kunin yung tubig sa loob. then bugahan mo ng hangin para matanggal.
higpitan mo lang yung bolts ng valve cover. pero wag masyado...
- Dec 2004
- 2
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 28th, 2004 10:06 AM #7kapag may leak na valvecover di gumagana yung paghigpit. just replace the valvecover gasket to remedy it.
re: wet plugs, this is probably just caused by worn spark plug oil seals. have those checked narin just to be sure... sayang plug kapag nabasa... it will foul easily
December 28th, 2004 10:11 AM #8
How much kaya papalit nang spark plug oil seals and valve cover gasket.
December 28th, 2004 10:36 AM #9
what engine? spark plug body ang basa or the tip itself? did you remove the spark plug? basa ng oil ang tip?
December 28th, 2004 11:53 AM #10
yung body itself not the tip nya.
Civic LXI po bossing.
Yung body nya basa nang oil nung tinanggal ko sya isa lang naman.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
