Results 1 to 17 of 17
    Ano kaya cause nito basa ang isang spark plug ko.
    saka yung gilid gilid nang makina may mga langis, Busted na kaya yung gasket head ko.
    Please advise naman mga bro. belikado kaya yun.
    Thanks
    engine wash? you went through a flood?
    oil at the bottom of your valve cover? prolly the valve cover isn't fixed tightly.
    nagpaengine wash nga ako. I dont know kung tubig sya or langis.
    yah yung bottom nang valve cover madami nga syang langis sa gilid gilid.
    ahh... nabasa nga yan sa engine wash. gamitan mo ng syringe para kunin yung tubig sa loob. then bugahan mo ng hangin para matanggal.
    higpitan mo lang yung bolts ng valve cover. pero wag masyado...
    Thanks Boss mazda
    Dec 2004
    pag car wash lang yan nakuha., external lang yan
    Nov 2003
    kapag may leak na valvecover di gumagana yung paghigpit. just replace the valvecover gasket to remedy it.
    re: wet plugs, this is probably just caused by worn spark plug oil seals. have those checked narin just to be sure... sayang plug kapag nabasa... it will foul easily
    How much kaya papalit nang spark plug oil seals and valve cover gasket.
    what engine? spark plug body ang basa or the tip itself? did you remove the spark plug? basa ng oil ang tip?
    yung body itself not the tip nya.
    Civic LXI po bossing.
    Yung body nya basa nang oil nung tinanggal ko sya isa lang naman.
    as long as not in the tip ok pa ang engine, you should only be alrmed if the tip is wet of oil. there might be oil condensation lang and when you had it washed it mixed with the water and went to the sparkplug.
    Nov 2003
    oil seals are cheap lang. maybe between 100-150/pc estimate ko. even if isang lang basa, i recommend replacing all 4 na since nakabukas narin.
    how much naman yung labor?
    Nov 2003
    you can actually diy it or pay a couple of hundred lang for the replacement at your suking talyer. kasama na dun linis ng VC and everything else dapat.
    cge dalhin ko minsan sa inyo. TY!!!
    hehehehehe. Ikaw ang suki kong talyer eh!!!
    Nov 2003
    hehe! tawag ka nalang kay toto... he can give you the complete breakdown para ma-fix na yung price
    seeya!
Basa ang spark plug
