Results 1 to 10 of 21
May 19th, 2006 11:56 AM #1
Mga Sir,
Ganito po yun, kagabi di ko ma-start yung sasakyan ko. namatay yung mga ilaw niya sa dashboard panel. ayaw din mag-start.
check namin yung battery, binuhusan ng tubig tapos konting linis. biglang ok na. nag-start uli.
then i notice, na pundido yung tail light. ginawa ko tinanggal ko yung bulb.
then..nakauwi na kami.
this morning habang nag-drive me. pansin ko yung speedometer eh hindi gumagana.
then napansin ko rin biglang lumabas yung symbol (in orange color) ng check engine.
normally kasi hindi ito lumalabas eh.
ano po kaya mga sir ang problema?
May 19th, 2006 12:44 PM #2
what is your car? when the check engine lits...well check your engine, could be a clogg filter, cleaner, etc. Could be your speedo cable snapped.
May 19th, 2006 12:56 PM #3
Mukang may problema sa electrical ang kotse mo. Pero and spedometer naman normally ay mechanical kaya di dapat sya apektado unless kung digital display ang speedometer mo.
May 19th, 2006 03:01 PM #4
i have honda civic automatic 96model. analog lang ang speedo ko. check engine lits only this morning. i tried it again. nawala na naman yung ilaw niya. pero mamaya ko masusubukan during driving kung mag-lit uli siya.
kung electrical ba ito...maayos pa kya ito. pansin ko rin na kalahati lang ng speedo ko ang may ilaw. yung kalahati eh e wala.
May 20th, 2006 12:55 AM #5
Sa Pajero ko, electronic ang sending unit ng speedometer. It costs almost Php5k and bolts up to the transmission housing.
Gumagana pa ba odometer at trip meter mo?
- Oct 2004
- 278
May 20th, 2006 01:35 AM #6electronic po ang speedometer ng mga honda, and pag walang signal from the sensor going to the ECU, iilaw talaga check engine light...
probably, you need to replace the sensor na sa may tranny... but have it checked na rin para sure...
May 20th, 2006 02:38 AM #7
Yung 95 Civic namin, analog din ang speedometer pero electronic ang speed sensor niya.
Kung pareho lang sana ECM/modelo natin, I can point you to a Honda website showing how to do DIY-diagnostics and resetting. My Civic is an SR 1.6 Vtec hatch. According to the service manual, the check engine light - Malfunction Indicator Lamp or MIL to Honda - will light up if you have a faulty VSS or Vehicle Speed Sensor. The diagnostics should reveal if the VSS is faulty.
It might be the same as yours. Hopefully someone else will come along and tell us.
EDIT: Sa tagal kong magbasa ng manual, nasagot na pala ni EssBLast edited by StraightSix; May 20th, 2006 at 02:40 AM.
May 20th, 2006 11:16 AM #8
Sir, do you mean Vehicle speed sensor is related to speedometer??
the check engine turn on when i drive approx. mga 3km.
but during start up...normal lang.
guluhan ako sa kotse ko eh.. heheh :P
- Oct 2004
- 278
May 20th, 2006 01:23 PM #9Originally Posted by kabuke0
ganun talaga.... galing sa VSS yung signal papuntang speedometer...
yung sa EG ko dati, nung sira ang VSS, may check engine light din talaga lagi...
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 20th, 2006 08:51 PM #10normally the vss will throw a code when you've covered a short distance na like 2-5kms na slow speed or if you go above 60kph.
replace it and reset the box and you should be ok.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
