Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Dec 2009
    Guys ask ko lang kung pano malalaman kung oblong na yung gulong. Nagpa check kasi ako kanina sa servitek dahil nag wi-wiggle yung sasakyan pag umaabot ng 80km. After checking sabi oblong na daw gulong ko. Acceptable sana kung isa o dalawa. Pero yung 4 na gulong ko daw oblong na!. 30k km ko palang nagagamit yung gulong saka 2012 yung manufacturing date nya. Neuton pala tatak ng gulong ko. Thanks!
    Like any serious sickness, get a second opinion, even a third
    Wiggle ang buong kotse o manibela?
    oblong tires should be obvious if you mount then let them spin at the tire balancing machine. kitang-kita yan kahit naked eye.
    Jun 2005
    magpa balance ka ng gulong. dun pa lang makikita mo agad kung oblong ang gulong. okaw mismo makakapansin nun
    Gamit man or hindi ilan years ba life span ng goma?
    AFAIK 6 years
    AFAIK 6 years
    AFAIK 6 years
    AFAIK 6 years
    AFAIK 6 years from the date of manufacture ang ginagamit, regardless kung kelan kinabit after the fact. But this is more to do with elasticity ng rubber. Kaya may mga reserve/spare tire ka mapansin na never masyado nagamit pero puro crack na dahil malutong na goma, expired na bale at delikado na ibyahe baka pumutok.
    Correct me if I am wrong though.
    Oblong usually cause is improper tire pressure over long periods of time of use/loading lang naman diba? May iba pa ba cause?
    AFAIK 6 years
    AFAIK 6 years
    Yung "tusok" vulcanizing repair nakaka oblong din daw.
    Dec 2009
    Quote Originally Posted by 17Sphynx17 View Post
    Bandang harap lang sir.
    Apr 2014
    Malalaman mong oblong yan kapag ang takbo mo is parang may bato ka palaging nadadaanan.
    posible, maaring ma-damaged na kasi yun steel wires sa loob ng goma dahil sa puncturing nung pantusok.
    Dec 2009
    Quote Originally Posted by sirkosero View Post
    Sige sir try ko uli. Huling pa balancing ko 3 months ago nung pina rotate ko yung gulong.
    Just had my tires rotated with spare sa toyota casa during my 5k pms. Do i need to do tire balancing din?
    Sep 2013
    Quote Originally Posted by Morz View Post
    definitely para sure. it won't cost so much at servitech etc.... hwag lang sa casa hulidam doon
    Quote Originally Posted by radz15 View Post
    Yes, that would be best as it is the simplest test to check kung oblong talaga.
    On another note, if hindi nga oblong and the wiggling is prevalent in the front at speed, have the guys try and check if it could be a worn out ball joint for the front tires or it could be worn out/damaged steering column/rod connecting to the tires causing the wiggling.
    This is what causing "wiggling" in our l300 FB rather than tires more often than not.
    Hope that helps.
    Dec 2009
    Hope that helps.
    Pa check ko yan sir. Thanks!
    Dec 2009
    Update lang. Ok na po gulong ko. Isang gulong lang sa harap yung culprit. Medyo bumukol sya gawa ng di daw pantay pagka pudpod. Nung pina balance ko halatang halata na gumegewang gewang. Buti nalang may spare tire kaya labor lang nagastos thanks sa mga sir!
    Dec 2009
    Mga boss buhayin ko lang uli tong thread. After 3 weeks bumalik nanaman sakit nya kada mag 80km takbo ko may vibration nanaman same sa unang ngyari. Pina balance at rotate ko na yung gulong. Yung dating may sira pinalit ko sa spare tire. Pero since sabi ng nag ayos pag iba daw tatak dapat daw sa likod. Bali yung nasa harap na gulong galing sa likod tas yung spare tire ang nilagay sa likod. Pansin ko parang may hindi maganda sa gulong based sa pic.
    Sep 2017
    happened to me in SLEX, may "rhythmic" sound (for lack of a better term) coming from the wheel especially when the speed increases. At first I thought it was my wheel bearing hub pero mabuti na lang may tire repair along Alabang-Zapote, when they took out the tire kita agad yung problema
Signs na Oblong ang gulong
