Guys! tanong lang ako kung ano problema ng Lancer 93 GLi ko, Minsan kac bigla na lang ayaw mgstart parang walang kuryente at pati yung busina nya e halos ayaw tumunog. i checked the battery pero fullu chared naman. I am using a maintenance free battery na may indicator so its easy to check it. Tapos tinanggal ko yung mga battery terminal jaz to check at napansin ko mainit yung negative terminal. wala naman ako makita na mali ang connection. so i placed it back at after two try to start the car bigla na lang nag start sya as if nothing went wrong na i travel ko sya long drive at wala naman naging problema after. tapos after a week the same happened.
Patulong naman po mga sir baka may alam kyo about my dilema pls p post na lang po.
