Results 1 to 5 of 5
    Jul 2005
    hello again, tsikoteers. yeserday i noticed that my radiator auxiliary fan is always on. dati hindi ganun. di ba pag na-reach na ng engine ang normal temperature meron sensor na mag-trigger para mag-off ang fan. How do i fix this? TIA.
    Aug 2006
    aux fan will be always on if the a/c is on(low speed).It will be on if it reach certain temp.Have your relay check.
    Jul 2005
    Quote Originally Posted by ronald_m View Post
    tama bro, aux fan of aircon is always on pag on din ang aircon. mali ako ng post. What i meant was RADIATOR fan always on even if it reaches normal temp ayaw mag-off. Pls help. Thanks.
    Aug 2006
    Quote Originally Posted by duncan_sheek View Post
    bro, check mo relay sa fuse box, baka open..
    Relay problem....check relay. On lang yan pag on din A/C mo bro.
aux fan always on
