Results 1 to 20 of 20
    Jul 2005
    I was told that there is this shop in banawe which has this machine which will suck all the ATF in your tranny instead of just the conventional draining.
    As far as i can recall from what he said, it's near MR2, Banawe.
    Do you guys have any idea what the shop name is?
    I dont think thats necessary at all.
    All OEM uses the drain method.
    Jul 2005
    ok thanks.......does changing the ATF more often be harmful for the car?
    i was planning to change it more often to replace the stocked ATF bit by bit.
    will that be fine?
    Feb 2005
    I dont think that be harmful to your ride but the cost is surely harmful to your pocket...
    yup you can never change your oil too often hehe...
    Aug 2003
    fronte motors in banaue has that service. it costs 2500 for vans like the starex and sedona, atf inclusive. service for passenger cars is cheaper but i don't remember how much.
    acenie: pls. post feedback about that service if ever you avail of it. balak ko rin kasi pumunta duon when it will be time for my scheduled a/t service interval.
    Apr 2004
    i was told that autotechnika in fairview does this flush...800 for medium size cars exclusive of the fluid.
    Jul 2005
    ok. i will post my feedbacks on that service.......actually it was toti cruz of zee who advised me to take that service. so, it must be ok.
    Jul 2005
    Quote Originally Posted by diesoline
    can you give me instructions on how to get there?
    thanks.
    Nov 2003
    there's no real way to get everything out without using a tonload of atf... you've got atleast half the capacity of the atf inside the torque converter kasi which can't be drained without taking the tranny down.
    Jul 2005
    Quote Originally Posted by speedyfix
    sir, yun nga raw po yung purpose nung machine.......to suck everything even those ATF in the torque converter........that way mapapalitan lahat.
    Aug 2003
    Quote Originally Posted by seednie
    thanks.
    it's at the corner of banaue and kabignayan st. near the children's hospital. if you are coming from the corner of banaue and e. rodriguez, kabignayan is the second (not sure) street. turn right, fronte is on the left side of the street.
    Jul 2005
    thanks diesoline
    Nov 2003
    they can get even the atf inside the TC? paano yun? the TC is sealed and only has one hole. i seriously doubt it but of course i could be wrong...
    Clean City sells this device that sucks used fluid through the dipstick hole...it uses a heat resistant straw...baka ito gamit nila...
    Aug 2003
    got this from http://www.currysauto.com/tech-transmission.asp
    Transmission Service
    By: Bill Shaw
    Recent Articles:
    One of the most critical, unobtrusive and, therefore, often neglected parts of a vehicle is the transmission. While it isn't as maintenance-intensive as the brake system, for example, both manual and automatic transmissions require at least periodic inspections if not regular service to prolong their life. But before we explain how to best service transmissions, a brief explanation of how one works is required.
    The transmission multiplies torque from the engine through a gear reduction and/or torque conversion. A typical manual transmission has anywhere from four to six speeds with the final or highest gear being either a direct 1:1 drive ratio or an "overdrive" ratio, less than 1:1. For the most part, they are trouble-free (except for the clutch, which can be problematic if adjusted incorrectly or abused). An automatic transmission, on the other hand, multiplies engine torque as it passes through the fluid coupling known as the "torque converter" and then through three or more separate gear ratios. The transmission oil is critical for lubricating the transmission and reducing friction. When the fluid breaks down and loses its viscosity, it no longer effectively lubricates the transmission. This causes premature and excessive wear and results in transmission failure.
    This logically begs the question, how often do I need to have my transmission serviced? And like many things in life, there is no straightforward answer. Service intervals will vary depending on how the vehicle is used and the operating temperature of the transmission. The leading problem with transmission failure is fluid breakdown due to overheating. And fluid life expectancy is directly related to the operating temperature of the transmission. Consequently, many transmissions fail long before they realize their potential design life because of heat. In an automatic transmission, for example, a normal operating temperature is about 215 degrees Fahrenheit. At this temperature, the oil should easily last for 30,000 miles (unless you have a new vehicle that is filled with Dexron III ATF which is supposed to be good for 100,000 miles). But for each 20 degree increase in operating temperature, the life of the fluid is cut in half.
    Cars that are driven at track days should be inspected before every event. When you periodically check the fluid level, pay particular attention to how it smells. You will notice a burnt smell long before the color changes. And, when you notice a strong burnt smell, have the transmission fluid flushed immediately.
    Therefore, and as a general rule for automatic transmissions - that are not tracked or autocrossed - Curry's recommends replacing the fluid every 30,000 miles. There are three ways to service automatic transmissions. The first is commonly referred to as a transmission service and consists removing the transmission pan, draining the fluid (about half of the total), changing the filter and pan gasket, and adjusting the bands if necessary. The second technique for changing the fluid is called suck and fill. With this method, the fluid is sucked out the filler tube then new fluid is used to refill the transmission. The last service method is a total transmission flush. In this case, a special machine is attached to the cooler lines of a transmission and the new fluid replaces virtually all of the old fluid.
    The biggest disadvantage to a conventional transmission service is that it does not completely drain all the old fluid. The remaining fluid, therefore, can form deposits on transmission components that can eventually lead to erratic shifting and even transmission failure. Using a transmission power flush and fluid exchange system extends fluid life and helps prevent leaks and expensive repairs. If the transmission is shifting and operating as designed, regular transmission flushes are the recommended procedure for prolonging the life of your transmission since it flushes almost all of the old fluid from the transmission pan, cooler and lines, and not just from the pan as with the first two methods. Flushes are also particularly important when converting from conventional transmission fluid to synthetic fluid (which is used under severe conditions such as commercial use, heavy loads, or towing).
    Unlike the fluid in an automatic transmission that is being constantly churned (which generates heat) and contaminated by particles worn off the clutch plates, the fluid in a manual transmission or transaxle has life pretty easy. Most manual transaxles use automatic transmission fluid (ATF) to keep the gears lubed. ATF works well because it stays much more fluid at low temperatures and this oil stays relatively clean and runs fairly cool. However, it should still be changed at 30,000 miles (60,000 miles if synthetic oil is used).
    The reasons you would change the fluid in a manual transmission more often are if you regularly track the car, or are experiencing hard shifting problems. And the only time you should have to add oil to a manual transmission is if the transmission is leaking oil. If you see any grease or wetness around the tailshaft or driveshaft seals, the oil level in the transmission or transaxle should be checked because it may be low. Needless to say allowing the fluid in the transmission or transaxle to run too low on lubricant can ruin it.
    Curry's has not seen a correlation between mileage and transmission failures. If the transmission is not abused and is properly maintained, it will last for the life of the vehicle. As related innumerable times above, heat is the number one culprit of transmission failures. We are firm believers that a periodic service/inspection is the best way to ensure that your transmission has a long life - and in this regard, fluid inspections and/or flushes/changes in both manual and automatics are critical to avoid premature transmission failure.
    If you have any comments, questions or suggestions please send them in an email to bill*currysauto.com.
    chieffy might be referring to the second method, seednie to the third. the only disadvantage i see in the second and third methods is that the a/t filter and pan gasket are not replaced.
    speedyfix, is changing the a/t filter in the course of the reqular transmission service practiced here too?
    Nov 2003
    you don't really need a machine to do that. all you have to do is cycle through the gears while draining and pouring atf inside simultaneously. sooner or later you'll flush everything out. it will take a lot of atf tho...
    diesoline, yes it can be done. sometimes tho the atf filter cannot be reached without removing the tranny. the cost of pulling down the tranny is what often makes customers think twice about this procedure.
    chieffy, i was talking to the owner of autoplus and they returned the machine that sucked oil through the dipstick after 1 use. it hardly got anything daw and was really inefficient. much much better daw to stick with removing the drain plug. hehe!
    Sep 2006
    You guys are really terrific! Just by reading your posts, it makes me appreciate the car more. it prompted me to check the ATF of my ride which I found to be needing more attention now that it has run more than 50T kms. Many thanks and keep it up.
    Apr 2006
    Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
    kabuke0, evs_13, GaLynxmo
    marami talaga akong matutunan dito sa tsikot.com
    Nov 2003
    GaLynxmo, that's great to hear!
ATF Flush
