Results 1 to 10 of 22
- Oct 2005
- 72
May 7th, 2007 07:40 AM #1Mga Sir, can you give me idea my ride is CIVIC VTI, and the ATF use indicated is DEXTRON II , I'm planning to change the ATF fluid to "CASTROL brand but DEXTRON III. Is there a problem with this ? anu ba differences ng DEXTRON II at Dextron III ?????
Pls educate me...... thanks a lot.
May 7th, 2007 07:47 AM #2
imho, i used petron premium ATF mas mura pa, about 145 per liter (sa may pedro gil cor san marcelino - dito kasi pinakamura ung oil and unleaded gas nila eh) dexron III compliant n din po sya, and mas ok n ngayon tranny ko. pina transtech ko din nga pala civic ko sa autotechnika i consumed about less dan 20 liters to fully clean my tranny.
May 7th, 2007 07:57 AM #3
You can use Dexron III on your car since it is backwards compatible to Dexron II. The difference is that III has a better cooling property than II along with detergents. If you want to use synthetic you can even use Mercon 5 as that is the equivalent. However, if it states that you should use III don't go backwards and use II as that can damage to your transmission.
- Oct 2005
- 72
May 7th, 2007 08:16 AM #4What about Castrol brand ATF Dextron III is it safe and more reliable to us this ATF regardless the price /?
May 7th, 2007 08:30 AM #5
basta mahalaga tama ang spec ng ATF, regardless ng brand.. pero syempre iba when u use synthetic ATF...
ako i used atf-dexron-2 spec na woth 85 pesos lang per liter..8 liters ang palitan ng ATF, not ung naddrain mo lang sa pan...
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 7th, 2007 09:09 AM #6
- Jun 2006
- 2,605
May 7th, 2007 09:15 AM #7
- Oct 2005
- 72
May 7th, 2007 09:15 AM #8Mga Sir. Ok lang gamitin ko Castrol Dextron III ATF para sa Civic VTI ? kasi nakabili na ko..... I understand maganda iton Castrol ? please advise. ?
May 7th, 2007 09:23 AM #9
MERCON is what Ford calls their suggested atf but is comparable to Dexron III, Mercon V is the synthetic atf that Ford came out with in 1997. SO if you want non-synthetic you would use Dexron III/Mercon and if you wnat synthetic it would be Mercon V. If you look at most Dexron III atf sold it is labeled Dexron III/Mercon as they are equivalent.
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
