Results 1 to 16 of 16
    Oct 2014
    Hi mga sir. San po kaya magandang magpaalign ng headlights parang antaas ksi ng low beams ko nakakasilaw para sa iba. Sampaloc area po ako pero open to other locations basta magaling lang gumawa. I've heard of shops having laser adjustment mukhang maganda ata yun. Thanks.
    Quote Originally Posted by Valharth1031 View Post
    what's your car make/model sir? baka kaya mo nang DIY ang adjustments niyan. it's just a few turns lang ng screw driver.
    Oct 2014
    Quote Originally Posted by benchman View Post
    I have a 2006 Honda Civic, sir. Medyo newbie ksi ako sir in general sa cars kaya naghahanap ako ng marunong. Kung may tips ka sir pano I'd appreciate it.
    just follow the instructions here; Headlight Aiming - 8th Generation Honda Civic Forum
    Oct 2014
    Ung problema sir is I dont have a place where I have at least 30 ft. I'll try eyeballing the adjustment for now.
    30ft isn't necessary, sir. yes you can eyeball the adjustments, you can try it against a wall then mark where your current beam is then adjust in small increments.
    Oct 2014
    Sige sir. I'll let you know what happens. Thanks.
    i DIY mine.
    i do it when it gets dark, in the workplace parking lot.
    the only special tool needed, is a long enough screwdriver, to reach the adjusting screws. (some cars prefer flat blade, others prefer philips.)
    consult your car manual to find out where these screws are, po, and determine how long the screwdriver should be.
    try it, po. it's actually fun! all misgivings disappear when you actually see the beam of light, moving to your command.
    and don't worry. "walang sasabog."
    Check mo muna bulb mo, inside the headlamp housing, baka baliktad o mali ang ang pagka-install ng placement ng H4 bulb mo. Before making any adjustment.
    Starmobile Up+
    i DIY mine.
    sideways din bro pwede adjust? sakin kasi yung driver side lang well lit LOL
    Aug 2013
    may ibang sasakyan na merong adjustment, yung corolla ko bro merong sideways adjustment.
    Quote Originally Posted by innova2013 View Post
    sige silipin ko maya ^_^
    kung sakasakaling di mo kayanin ng DIY, LA Cars has this service. I've seen someone having his HLs aligned when i was there. Laser alignment tawag nila. Dunno how it works though.
    Quote Originally Posted by 1D4LV View Post
    Thanks! Sana mura lang
    Btw meron nito sa bf homes bro diba?
    Sent from my E5553 using Tsikot Forums mobile app
    sabi nga nung nasa itaas... depende. may meron, may wala. madali naman malaman, e. kung mukhang kulang ng pangalawang adjusting screw...
    yup, meron.
Any recommendations where to have headlights aligned and adjusted?
