Results 1 to 9 of 9
    Jul 2003
    my ride is mitsu adventure s.sport gas fed EFI engine.ganitong nangyari. naka park ako sa me parksquare. i tried to start my car at nag ka-crank lang ang makina pero ayaw umakyat ang fuel sa me combustion chamber.me fuel naman ako kakapagasolina ko lang at check ko ang primary fuel filter di naman barado.when i checked kung mababasa ang palm ko habang me nag iistart(ng kasama ko) tinakpan ko ang bandang throttle para I CHOKE nya di nabasa ang palad ko.di naman timing belt at me suction pressure sya. any idea? thank you in advance!
    p.s. i tried to bring my car at citimotors makati pero d sila tumatanggap ng service daw due to labor problems...
    Spark Plugs or your fuel lines may be clogged.
    Mar 2003
    check everything regarding fuel delivery.. injectors,fuel lines, fuel filter. etc. etc.
    na tune-up na ba auto mo?
    looks like you don't have ignition. check your ignition fuse.
    Battery? Have you tried honking horns while headlight is on and engine is off?
    mukhang walang kuryenteng dumadaan sa fuel pump mo, tignan mo baka busted lang ang fuse ng para sa fuel pump
    Jul 2003
    thank you sa reply guys! nasa casa na at ang sira ay fuel pump daw.
    Ano nasira dun sa fuel pump? hehehehe.
    Jul 2003
    ayaw ng bomomba! hahaha
any idea?not so sure kung anu ang nangyari.
