Results 1 to 10 of 20
November 2nd, 2005 04:30 AM #1
it's time to replace my sparkplugs.
may nagsabi sakin maganda raw cold sparkplugs ikabit ko.
ano ba mga magandang brand and model?
ung platinum tip din pla dapat
paki indicate na rin price at san makabili
tnx
- Jun 2004
- 1,311
November 2nd, 2005 05:26 AM #2If your engine is unmodified, stick to what your car manual recommends. Usually NGK or Denso.
November 2nd, 2005 07:47 AM #3
Originally Posted by kenet_3
Using cold plugs in a stock non-turbo engine will just result in fouled plugs when driven in daily traffic.
November 2nd, 2005 09:27 AM #4
for the 323... the manual states that you can either use a cold or hot sparkplug.
ok ang cold plugs kapag lagi kang nasa highway / long drive. pero kung city driving ka... dapat hot plugs.
and kapag nag foul-up ang cold plugs, talagang ramdam mo.
November 2nd, 2005 06:33 PM #5
may nagsabi kasi sakin na cold sparkplugs, meaning yung higher heat rating (tama ba?)
kasi naka-advance ang timing ko and may engine knock. cold spark plugs daw ang solusyon dun para di mag-knock
November 2nd, 2005 07:12 PM #7
Cold plugs help in curing knock in advanced timing but it's not a necessary item.
What fuel do you use? If you advance your timing its adviced to use high octane like Petron Blaze or Velocity... or your timing is just way too advanced.
Check what your stock plug is and get the next heat range... for example if you're using an NGK BKR5E, switch to BKR6E.
November 2nd, 2005 09:53 PM #8
mag Bosch Platinum ka na lang. Yun orig ha. may 4 tip platinum na dito pero medyo mahal.
November 3rd, 2005 12:30 PM #9
me, i'm using denso iridiums. but my engine is turboed. so best stick to OEM spec.
November 5th, 2005 04:01 PM #10
Originally Posted by vinj
so i guess stick na lang talaga ako sa rating na un?
pero may nakita rin ako sa mga bosch plugs, may counterpart yung BKR6E na platinum tip. ok kaya un? ramdam kaya difference? P130 per piece lang kasi e
Tentative price increase from removal of the pickup tax exemption leaked:
Toyota Hilux (9th Gen)
