Results 1 to 10 of 17
- Jun 2007
- 15
June 21st, 2007 09:13 AM #1mga bro, im just curious about the tune up ng car, newbie po ako d2. ask lang po kung ano usually mga ginagawa sa tune-up ng car.
kasi po dati ave. ko po sa kilometer/Li ay 10-11 kph nag palit lang po ako ng distributor tingin ko po ay lumakas n sa gas yung oto ko. car ko po ay AE92.
maramiing salamat po sa mga mag re-reply
carlo_lsy
Tsikot Member Rank 4
- Jun 2006
- 2,605
June 21st, 2007 09:41 AM #2usual tune up:
change spark plugs if needed
check high tension wires
change oil
replace fuel filter
clean or replace air filter
check transmission fluid, top up or replace as needed
check belts for damage and correct tension
check coolant level add/replace if needed
check hoses for damage
June 21st, 2007 09:53 AM #3
kung carb ang engine, spray some carb cleaner sa carb para luminis ito.
spray some contact cleaner sa distributor para mawala yung scales sa mga contact points sa loob ng cap.
check the engine's timing using a timing gun.
June 21st, 2007 10:57 AM #4
Now youve got all the answer. All you have to do now is, do it yourself (save money for labor))or bring em to shop.
- Jun 2006
- 2,605
June 21st, 2007 12:30 PM #6Best to check your manual kung kelan palit ng fuel filter.
Kung carb ang oto mo at plastic lang ang fuel filter, mura lang naman ito at madali diy. Kung tama ang memory ko every 10,000 kms ang palit.
Kung EFI at metal na fuel filter, medyo matagal ang sched at mahal ang filter. Yung sakin every 40,000 kms daw according to CASA, wala kasi sa manual.
June 21st, 2007 12:32 PM #7
yung ae92 nya does not have a contact point.
wonder kung surplus yung distributor na nilagay mo. it could be that some of the parts inside are already out of specs, like the pickup coil, iginition coil and the clearance between the rotor and pick up coil.
kung brand new ang nilagay mong distributor (brand new cost more than P20k plus), you can rule out the distributor as the culprit in your higher gas consumption.
aside from what userfriendly enumerated, consider also replacing the condenser kung hindi pa napapalitan. this is the one screwed outside the distributor
- Jun 2007
- 15
June 21st, 2007 01:15 PM #8sir, 2nd hand nga po yung nabili kong distributor, ang sira lang daw kasi dun sa dati kong distributor ay yung igniter. since 1 module na yun kaya napalitan n lahat. pwede ko po bang ipakabit yung igniter lang dun sa luma kung distributor? para ma maximize parin yung specs. nung dti. kasi pansin ko mula nung palitan ng distrbutor prang lumakas sa gas.
salamat po muli sa mga mag re-reply...
carlo_lsy
- Jun 2007
- 15
June 21st, 2007 01:18 PM #9sir, 2nd hand nga po yung nabili kong distributor, ang sira lang daw kasi dun sa dati kong distributor ay yung igniter. since 1 module na yun kaya napalitan n lahat. pwede ko po bang ipakabit yung igniter lang dun sa luma kung distributor? para ma maximize parin yung specs. nung dti. kasi pansin ko mula nung palitan ng distrbutor prang lumakas sa gas.
carlo_lsy
June 21st, 2007 02:04 PM #10
yhap, pwede. dapat igniter lang ang pinapalitan mo kung yun lang ang sira.
ano ba problem bfore, if i may ask?
