Results 1 to 10 of 11
- Oct 2005
- 22
November 21st, 2006 01:02 PM #1matagal na po akong browser at registered di lang po ako nakakasali sa mga discussions. meron lag po akong tanong.
someone told me it's a vaporizer. tama po ba?
it has hose on top that that goes into carb. its has hose that goes under the engine papunta yata gas tank.
according to a quick search it vaporizes (kung vaporizer nga) the fuel so that it can be burned easily. nasisira po ba ito? what happens kung defective po ito? will it contribute to a high gas consumption kung palyado na?
car is a 1990 toyota corolla 16 valve (ae92).
thanks po
November 21st, 2006 01:07 PM #2
Charcoal canister. Absorbs vapors from the return line of fuel tank and brings it back to the engine for burning again, and no need for the vapors to escape to atmosphere (toxic kasi).
That, or fuel pump
ae92?
November 21st, 2006 01:37 PM #3
he he i guess ang na search mo ay vaporizer ng LPG. tama si mbeige charcoal canister ito, a part ng evaporaitve emission system. dito nakokolekta ang gasoline vapor from the fuel tank then pinpurge ito sa intake ng engine for consumption. very rare masira ito kasi wala namang moving parts kadalasan may leak lang or crack, if so makakaamoy ka ng gas.
- Oct 2005
- 22
November 21st, 2006 02:33 PM #4hmmnn.... minsan nga ay amoy gas pero wala akong masilat na basa. will dismantle it to check.
im in a never ending search how to lessen the consumption of my ride. 5 to 6 km lang ako per liter on city driving, no matter how light i step on the gas. same route everyday. when i was using 1.3 lancer (97) and 1.6 altis, i was registering 8 km per liter, kaya may comparison ako.
compression test was okay and had my carb overhauled ganun pa din.
kung may leak kaya lalakas sa gas, even though vapor lang ang dumadaloy dun?
haaay, imbestiga, imbestiga, hanap, hanap ng solusyon....
anybody out there who may have any suggestion?
- Oct 2005
- 22
November 21st, 2006 04:33 PM #6oh, what i mean is just remove it from its location by removing it from its brace and remove the hoses and inspect it for leak not really open up the can. okay lang ba yon?
November 21st, 2006 04:36 PM #7
Basta well ventilated yung area, I suppose with care pwede rin. Basta wag mo lang buklatin, they created those canisters because of the toxic fumes so they should remain closed. Make sure you pinch the hoses before you remove the canister para di kumalat yung fumes.
November 23rd, 2006 10:43 AM #8
- Sep 2005
- 103
November 23rd, 2006 11:19 AM #9Medyo malakas nga sa gas ang ride mo, talo pa nya ang 2.0 na efi engine. baka nga may leak ang fuel line mo, that usually happens to a 15 yr old car....
- Oct 2005
- 22
November 23rd, 2006 11:27 AM #10malakas talaga eh, even after tune up ganun pa rin ang consumption.
looks like this version (7th Gen) will be its last After 36 Years, Subaru Is Ending The Legacy...
2020 Subaru Legacy
