Results 1 to 14 of 14
    guys patulong naman.. kung ano ano na ginawa ko dito...
    amoy usok sa loob ng car ko everytime I get around 80 KPH. bad trip tuloy di makahataw! hehehe
    anyway pinaseal ko na permanently yung fresh air vent kasi this was the first reason I could think of. Pinatingin ko na rin fuel lines (although di ko sure kung tama yung pag check nila) ala naman leak.
    Ano kaya dahilan nito mga pre? the smell seems to come from the drivers side pag high speed lang talaga.
    Magaling yung mekaniko ko, kaso talagang di nya masolve tong problem ko na toh for 1 year na! baka naman may masuggest kayo na tignan namin or maybe siguro recommend a shop na that can probably do a better job on this. MAkati sana kung meron(demandin noh!). Salamas!!
    Jan 2008
    better give other details like type of vehicle, age, is it converted?? etc.. so we can have idea where could be the problem...
    97 mazda 323 sedan. thanks
    Jan 2008
    what kind of smell ba naaamoy mo?? fresh gas?? or exhaust gas?? kung exhaust gas ang naaamoy mo check mo yung exhaust system mo baka may butas or leak yung linkages...
    kung sa driver side check mo baka natanggal yung rubber cover ng electrical wirings mo from the engine bay going to your cabin (located at engine firewall) kung A/T yan mazda mo check mo yung provision hole para sa clutch pedal baka natanggal yung cover..
    check the valve cover gasket of the engine. pag worn out na you might be leaking exhaust fumes under the hood, this might be one of the causes. i've watched this on wheeler dealers sa discovery hehehe
    thanks guys! sige pa check ko yung mga sinabi nyo
amoy gas/usok sa loob ng car
