Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
    sirs.. pwede po patingin ng ilustrations or pic on whats in it...? tnx po... alvincochua*hotmail.com tnx
    Dec 2003
    This is getting interesting. Pahingi din ng email about the thing. Gusto ko kasing tanggalin yung CAT ko dahil restrictive. Parang bali wala yung headers ko. carloi*tri-isys.com. Zero emmission na kaya ako and at 150% power and fuel efficiency if I remove my CAT, install EGO AND Aerogas? Will it be worth my P10,000 investment?
    Check your e-mail. TY for your interest.
    Rene:nerd:
    Remove your CAT. You don't need the AEROGAS! Install the EGO plus put CYBERLUBE (*Php 545/250ml bottle good for up to 5 liters of Oil) after Oil Change. Investment will not be more than Php 6,500. Check your mail.:nerd:
    Dec 2003
    Thanks for the email. To create the venturi effect that you've been mentioning, your device will have to restrict the airflow of the exhaust system (ie from 2" to 1.5"). This will increase the velocity of the gas and will create a low pressure area which I assume is where the outside air is being drawn in.
    This will not increase the velocity of the gas before the venturi throat which will not contribute to the efficient scavenging of the cylinders.
    Think of a water hose. As you squeeze the tip of the hose, the water shoots out faster and farther. This does not mean though that more water is coming out of the hose.
    Another thing, I use Mobil1 in my engine. I don't like putting any additives in there that may break down the delicate balance of my oil.
    Punta na lang ako sa World Trade on the second week of Jan. Do you have an exact date already?
    Carloi,
    The World Trade Exhibit is tentative only, if might not push through. If you want actual DEMO/Testing on your vehicle, contact me ASAP at (02)874-0183 (Res.) // (02)757-6031 (Off.)//
    (0926)3031871, we could go to Mr. Alegre's Office (Proj. 3, Quezon City). Also, watch in "Magandang Umaga Bayan" this week for a segment on EGO.
    carloi,
    just a side note... i won't recommend removing your catalytic converter if you care about the air and those who inhale it.
    interesting topic.... I wonder if the DENR/DOST will install this in their fleet?
    Originally posted by mbt
    carloi,
    Right, if you already have a catalytic converter installed in your vehicle, no need to remove it. The EGO will complement it.
    I thought that CAT meant CATALYTIC COMBUSTOR (from Aero-Gas). ;)
    is this a tailpipe end thinge? i had one removed when tested on our emission testing center, dahil istorbo sa pagpasok ng probe, wala naman nagbago sa takbo/andar ng makina nung natangal
    Yes, you only need to install/weld the new ALEGRE GAS OXIDIZER (EGO) at the tip of your vehicle's tail pipe and guaranteed to stop smoke belching, increase engine power (5 - 8%) and save on your fuel costs (up to 25%). Send me an e-mail at: add616reneb*cyberlink.net.ph for details/literature of the device. TY.
    Rene
    BTW, what was removed in your car when you had it tested at the emission testing center?:confused:
Alegre Exhaust Gas Oxidizer (ego)
