Results 1 to 10 of 24
February 18th, 2005 03:20 PM #1
Hi! i'm kinda new here and am desprately in need of help. My problem with my car is that it's like being pressed up and down from the front left corner of the hood and from the right corner of the trunk alternately!!! what could be the problem here? I had the front shocks checked and the mechanic dicovered that the left shock mounting was defective and had it replaced with a new one. But when I test the car for a drive there was still this "dribbling" although it became lesser it seems, it still makes me uncomfortable. I'd appreciate it if you could help me out on this, Thanks in advance, God Bless!
February 18th, 2005 03:27 PM #2
check your tire pressure too. it may be too high than the recommended psi.
February 18th, 2005 03:49 PM #3
Thanks ssaloon, all 4 wheels are 29psi and their sizes are 185x70x13 is the 29psi within the recommended psi?
February 18th, 2005 04:57 PM #7
what van? dun sa starex reco nila 40 sa front then 65 sa rear.
check dapat mabuti yan dribbling....baka ma double dribble ka dyan..turnover yun. hehedyok!
February 18th, 2005 05:11 PM #8
or maybe the tire has uneven wear? thek if its oblong? thats why its dribbling
February 18th, 2005 05:37 PM #9
oo nga baka may oblong lang na tire check mo..
check dapat mabuti yan dribbling....baka ma double dribble ka dyan..turnover yun. hehe dyok!
February 18th, 2005 06:57 PM #10
big possibility na defective ang tires.. lalo na kung recap lang.. kung brand new naman ang tires ipa camber mo baka nakabaliko ang settings..
A little ot: I disputed several charges credited to me a month ago and mptc finally corrected ...
cavitex easydrive error
