Results 1 to 6 of 6
- May 2004
- 66
June 15th, 2004 10:06 AM #1Hello peeps,
Curious lang ako, yong airbag ba sa RAV4 pwede ma-disable
anytime(i mean, meron lang switch na p-pindutin). Like in case na yong uupo sa harap eh bata, disable muna yong passenger side airbag pero naka-enable yong sa
driver side.
Thanks ng marami...
June 17th, 2004 12:54 AM #3
no you cannot unless there is a cut off switch installed by the manufacturer... you can turn it on or off using your ignition key i guess in your case toyota did not install one maybe because it is not yet mandatory there in the philippines but you can just ask toyota dealers about the option of putting one, one more thing dont mess up your supplemental restraint system air bag other than qualified service technician's...i have one installed in my tacoma here's the link www.pbase.com/image/15571292
peace out
caleLast edited by Cale; June 17th, 2004 at 02:44 AM.
- May 2004
- 66
June 17th, 2004 09:23 AM #5
nope... we don't have that option here in the philippines....
actually, there are a lot of options available for the rav4 that was deleted here. like adjustable headlights, double lock systems (you can only open the doors of the rav4 using the keyless entry), backup sensors, 2-din stereo with car info, etc.
- May 2004
- 66
June 17th, 2004 10:00 AM #6Originally posted by mazdamazda
In that case, yong option mo lang talaga is pa-disconnect permanently yong passenger side airbag ? Or is there any
shop around which can do such conversion?
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
