Results 1 to 14 of 14
    guys i need your advice. yesterday, me and my family went up to my in-laws at tagaytay. somewhere along the way, i felt my vehicle having this vibrations as i was going 100kph. i have driven my vehicle at this speed before even reaching up till 120kph and no vibrations have occured. this is the first time i have felt it in my vehicle. even my wife made the same comment. another thing that we noticed is that when i change my gear to 3rd or 4th gear, parang "kumakadyot" sya. i didn't change my driving habit when changing gears. pero kapag change from 1st to 2nd and 4th to 5th wala naman. i know the fact that nangyayari ito kapag mababa pa yung speed tapos nagchange gear ka na e ganun yung feeling. usually i change to 3rd gear at 25kph and to 4th gear at 45kph or before my rpm reaches 2000rpm. any advice po? btw, thanks for reading, medyo mahaba po i know. i just want all readers to understand what the situation is para mas clear. guys advice po please. nga po pala, i'm driving a mitsu adv ss 02, i just changed my oil recently. thanks in advance.
    hmmm.... need wheel alignment? camber adjustment?
    Jun 2005
    Could be tire imbalance. If the vibration does not seem to affect the steering, it's probably one of the rear wheels.
    Have your car's underbody washed and see if it still shows up. Sometimes, dried mud can cause rotational imbalance on the wheels.
    Your vehicle is still relatively new, so it's probably not a worn U-joint or an unbalanced propeller shaft.
    An extreme angle to the U-joints will also cause vibration, but this usually starts to happen at lower speeds. Just in case, make sure the vehicle did not undergo any major modifications to the ride height, which may cause uncorrected angles in the driveshaft.
    so far wala naman me pinagagawa to adjust the height of my vehicle. try ko po yung suggestions nyo. medyo matagal na nga walang underwash vehicle ko.
    Check mo din engine support.. baka sira na
    Sep 2004
    buong katawan ba ung vibrations o may specific area (ie. likod, harap)? try mo muna patignan ung cheapest suspect ie. wheel allignment/balance. kelan last wheel allignment mo?
    buong sasakyan. just had my wheel alignment 2 months ago.
    Jul 2005
    Quote Originally Posted by jvdejesus05
    how's your tire condition? Rim condition? nalubak ka ba lately?
    Jul 2005
    any unusual sounds ?
    wala naman. actually i'm gonna change tires na po.
    Jul 2005
    ok. pls be reminded lang sa tire balancing bago kabit ung bagong gulong mo.usually standard procedure yan sa mga tire shops pero iba wala.go for wheel alignment check after kasi bka nagbago yan during extreem vibrations lately.advice kanaman ng shop kung worn out na ang mga ball joints mo......camber check mo narin.....
    Aug 2006
    we have adventure 98 4d56.
    tanong ko lang po bakit kapag nasa 40kph pataas may "wig wig" sound parang galing sa ilalim ng kambyo,basta parang sa ilalim bandang gitna galing ang sound. wala naman effect sa takbo ng sasakyan,derecho lang kaso may wig wig wig sound lalo kapag derecho at spaltado daan.nakaka irita tuloy. pati nga pala speedometer needle masyadong magalaw.na try ko nga tanggalin muna speedometer cable kasi inakala ko baka sira lang cable kaso andun pa rin yung wig wig sound kahit naka tanggal na yung speedometer cable.
    ano ano kaya mai suggest niyo about sa case ng adventure nmin?
    Aug 2014
    Hello xt7.... same yang sound na naencounternko ngayon.... any idea kung ano yun.
    Aug 2016
    Quote Originally Posted by Xt7 View Post
    Puede po malaman ano naging problem at solution? Parang ganto rin po case ng sasakyan ko adventure 2016 model. nagpark kami sa mcdo last week, inclined ung parking. Pag alis namin, dun nagstart ko na marinig ung sound din parang sa drivers sound. masakit s tenga ung register ng sound pag tumagal tagal nagdadrive. at kahit smooth road, parang rocky at naririnig ko ung sounds na parang 'jug', jug or medyo tunong ng kulog.
Mitsubishi Adventure Problems
