Results 1 to 15 of 15
    my parents bought a 2nd hand Corolla GLi 1.6 A/T, so far okay naman and casa maintained from previous owner..
    ang unang tanong ko is, okay na ba ang ordinary unleaded dito? meron bang minimum RON (research octane number)?
    thanks
    Quote Originally Posted by revoGSX
    thanks
    i use shell unleaded in my ae111. no problems.
    Jan 2004
    I use either Caltex Silver or Shell Unleaded depende sa mood. Basta halos ubos bago magpalit... previous owner goes for Petron all the way. Wala namang problema, though M/T sa kin.
    Jun 2005
    since injected yan wala naman pblema pag mga carb type kasi may tendency na totope makina.
    naayos pa ba yung OEM na TVSS nito? sira na daw sabi nung original na may-ari, kaya ngayon eh walang alarm
    o mag aftermarket alarm na lang kami?
    thanks..
    We used to have one until recently ('99 1.3 LE)... the 1300 engine didnt turn out to be as durable as we hoped it would be though (got busted piston rings and a had to overhaul the PS)... but it was very easy and cheap to repair. Other then that the car was really good to bring around the Metro and is pretty fun to toss around the corners because of the short wheelbase and light weight.
    Jan 2004
    Anong sira nung alarm sir?
    naka-disable na yung alarm and hindi binigay nung nagbenta yung 2 OEM alarm remote kasi nga sira na daw, central lock na lang ang ayos..
    pa-install na lang kami ng aftermarket alarm, ano kaya ok na alarm na pwede buksan yung trunk from the remote?
    thanks
    thanks
    ang nakalagay sa manual para daw sa 4a-fe ron 95 eh. kung titingnan mo yung ordinaryo na unleaded 93 lang. yung sa akin ginagamit ko premium lagi.
    ghosthunter ok lang ba ang lower ron as per your experience?
    parang nasagot na sa mga naunang post pero tinanong ko pa rin para sigurado. kahit po hindi si ghosthunter pwedeng sumagot. salamat!
    Feb 2005
    Mas ok higher RON syempre.
    Aug 2005
    okey yata yan kpag unleaded kasi fuel injected na pero kung carb dapat higher octane rating like xcs.
    Apr 2004
    i use caltex vortex gold 95octane. napansin ko lang na gumanda fuel economy gumanda yung hatak. before i use vortex silver.
    May 2005
    Quote Originally Posted by carlocaraddict
    same here ,galing din ako sa Vortex silver .
    after ko na try ang Vortex gold feel ko ang difference
    Dec 2010
    Anybody know where I can source those OEM yellow foglights for the AE111? Thanks!
    Feb 2010
    Ah finally! Nakakita din ako ng thread for AE111! Hello fellow AE111ers, just wanted to ask regarding sa mga rattling noise coming from the dashboard, passenger side? Well aside from the age of the car, what are the usual causes of this and is there a way to replace some parts? Just had the engine support nearest to that area replaced and very significant ang binawas ng mga vibrations since then. Any tips po?
AE111 Corolla dito tayo (1998 and up ata)
