Hey'ya guys. I am planning on doing a full upgrade and a makeover to my HM Contessa (1983). The original car was made in the days when our economy was still not open to foreign trade. I really found the ride + comfort of the Contessa surpass most imports available today.
Anyway, I'm planning on doing a complete upgrade. For now, I'm focusing on the engine, transmission, and suspension. If anyone can give me an idea as to what engine, transmission+clutch can be fitted in the car, it will greatly be appreciated. I am not interested in smashing records. I am more in for the smooth ride. Here are the tech specs of the original components:
ENGINE
Type: OHC (Isuzu 1877cc)
No. of Cylinders: 4
Capacity: 1817 cc
Bore: 84 mm
Stroke: 82 mm
Compression Ratio: 8.5
Max. Power: 75 HP at 5000 rpm
Torque: 13.8 kgm at 3000 rpm
Cooling: Water cooled
Transmission
Clutch Type: Diaphragm
Diameter: 215 mm
Gear box no. of speeds: 5
Ratios 1st 1) 3.736
2nd 2) 1.963
3rd 3) 1.364
4th 4) 1.000
5th 5) 0.775
Reverse: 3.402
Synchromesh on: All forward gears
Final Drive Ratio: 3.417
Drive: Rear
Suspension
Front Type: Independent front suspension with coil springs-wishbones and anti-roll bar
Shock Absorbers: 2
Rear Type: 5-link Rear Suspension Coil Springs, Anti-Roll Bar and Panhard Rod
Shock Absorbers: 2
Any ideas on what parts can be used in the above areas will be greatly appreciated. I am not planning on refitting or repairing the engine. I'd like to work with new parts. Thanks for the time guys. The pic of the HM Contessa is on the thumb below.
