Results 1 to 7 of 7
May 13th, 2004 11:52 AM #1
gusto ko sana mag add ng fan na sasabay dun sa auxiliary(?) fan kapag nag on/off yung A/C, pwede ba yun?
anybody here done this? Paano yung electricals nun, meaning paano ko sya pasasabayin sa fan ng A/C?
Thanks
May 14th, 2004 02:28 AM #2
just connect one wire of the fan to the body and the other to the A/C compressor wire or better yet, install a relay. this would insure solid current from the battery to the fan. be sure of the rotation of the fan. should be sucking in air if installed infront of the condenser. reverse the wires to reverse the air direction.
May 14th, 2004 02:37 AM #4
much cooler ang condenser. the condenser's job is to cool the "hot" refrigerant passing thru it.
May 14th, 2004 02:43 AM #5
ah so sa gas lang siya?
sir alfred..napansin ko kasi..my safari IS VERY SENSITIVE TO HEAT.
pag mainit..RAMDAM NA RAMDAM ko talaga ang hina ng batak..pag malamig like pag gabi..super sarap at ganda ng takbo....
ewan ko ba..napaka sensitive niya...usually kasi hindi ko naman nararamdaman sa ibang kotse un...
pero sa safari..super ramdam mo ang effect ng init....
May 14th, 2004 03:14 AM #6
kaya nga may turbo intercooler para relatively cold air ang pumapasok sa intake ng engine. kaya yun intake hose natin nasa gilid kumukuha ng air at hindi sa loob ng engine bay.
It looks like solid state batteries are the next big thing. Will manufacturers allow retrofits to...
All New Toyota Corolla Cross
