Results 11 to 17 of 17
March 1st, 2007 09:23 AM #11
heheh ...thats a very sad excuse coming from a dealer
sir vinsanity ano ba year and model ng auto mo?
Tsikot Member Rank 5
- Nov 2003
- 3,848
- Mar 2006
- 58
March 1st, 2007 10:21 AM #13Hyundai Sonata GLS 2000 model ng car ko. sir speedy baka pwede ko pacheck sa inyo kaya lang takot ako sa traffic sa Shaw, hirap talaga ng preno.
- Nov 2003
- 3,848
- May 2004
- 903
March 2nd, 2007 11:00 AM #15pa tow mo na lang para safe... Dont ake risk baka susunod na hanapin mo engine..
- Aug 2006
- 47
March 9th, 2007 02:55 AM #16sir maki sagot lang,yes first step eh fuse, but then di dapat lumambot ang brake mo,yung Elantra ko mga sa pinas di ko na pinagana abs.k pa din,basically dapat ok pa and conventional brake mo.abs only works when you slam the brake at a certain speed para di mag lack ang mga brakes mo and cause swerving,yun lang.and abs light should be on continously kung faulty yan................................ty
March 9th, 2007 04:52 AM #17
When was the last time you had the brakes serviced before the spongy pedal? How did they bleed the system? Did they use a vacumm pump? If they did that can cause air pockets between abs pump and the master cylinder on some abs systems which will cause the spongy feel. Not sure if Hyundai has one of those systems.
so i went looking under the hoods of my city hatch and jimny. other than the plastic upper/lower of...
BYD Philippines
