Results 1 to 15 of 15
    Around how much with labor?
    95 Altima with 81K on odo. Thanks
    Salamat.
    Jul 2005
    depende sa pagdridrive mo but I think kung chain yan it should last you for about 100k miles.
    Just to give you an idea:
    Timing Chain Tensioner - Upper
    13070-00004
    Altima
    1993-1997
    $56.69
    Timing Chain Tensioner - Lower
    13070-00003
    Altima
    1993-1997
    $56.69
    And I hope the cost of labor isnt as much as replacing the chain itself
    Jul 2005
    kung nasa amerika ka mahal pa ang labor kaysa sa parts.. pero kung sa pinas bigyan mo na lang ng kalahating case na beer o gin ok na yun
    Nov 2003
    theeved, masyado pa maaga yan. no need till you're around 140-150k pa. unless umingay na sya...
    Karding: SALAMAT!!!
    Migs: Ah, ok, di pa naman actually, mga half a sec may light noise sya during morning start, after that wala naman at all, only in the morning does that light half second clatter is audible.
    Kapag naging tunog diesel na yang gas engine. :D
    Jul 2004
    Hindi ba dapat sabay ang replacement ng chain and tensioner?
    How you know that the noise is coming from tensioner and not on chain itself?
    Ano ba tunog ng chain/tensioner? How do you distinguish is from the engine noise?
    Nov 2003
    theveed, no problem... about the slight noise, i don't think it should be a big problem. if it gets worse tho that's when you should start to worry.
    field master, the engine itself shouldn't make that much noise. if it does then that's probably the shims shouting to be replaced. engine noise will typically be heard right on top of the valve cover... timing chain noise will be only on one side. not that hard to distinguish if you ask me... just notice where exactly the noise is comming from.
    theveed, yung tunog non sana its not the chain hitting the chain guide. If you let the problem persist, baka magaya ka sa 240SX ko na kailangan na ng engine swap. AFAIK, sakit ng Nissan 240SX ang chain hitting the chain guide. Baka lang kasama sa Sentra ang mga sakit na ganyan.
    Nov 2003
    if something is hitting baka sira lang dyan is yung hydraulic na tensioner. easy naman to see if that is working.
    I doubt na its hitting the chain guide Kards. Kasi kahit irev ko redline walang tunog talaga, early morning start lang meron (very short noise). Isip ko kasi baka sa langis... Regardless, hehe papacheck ko din kay Miggs next month during oilchange and tuneup
    Nov 2003
    owkidoks! we'll see what we can do about the noise next month
    Jan 2003
    ...my dad's C220 is due for oil change and tune up. 100k na tinatakbo, so re: the timing chain; upper and lower tensioner lang ang bibilhin ko for its maintennance, tama ba?
    ...and yes, parang tunog diesel na siya, please advise.
    Nov 2003
    while the engine is open you might as well replace everything that needs replacing para you extend the service interval again.
Timing ChainTensioner Kelan ang scheduled replacement?
