Results 1 to 10 of 18
January 11th, 2005 03:24 PM #1
Mga kapatid, post ko na din dito... Need your advise.
This is my first time to replace my ride's timing belt. I'm just not sure what are the parts to be replaced, aside from the timing belt itself. Should you know the price range of the parts, please include.
Below are some parts mentioned, which I'm not really sure if needs to be replaced/repaired and/or present in my current ride:
Timing belt - A & B daw?
Tensioner - A & B ?
cam shaft
crank shaft
oil pump
oil seal
balancer oil seal
Did i miss anything?
Appreciate your feedback.
ride is a 97 galant SS
Thanks in advance!
January 11th, 2005 03:46 PM #2ride is a 97 galant SS
Yung Timing Belt A&B na sinabi sayo para yan sa Galant VR V6, AFAIK.
What you will need are the ff:
Timing Belt.
Tensioner Bearing
Optional but recommended:
Cam Shaft Oil Seal
Crank Shaft Oil Seal
Water Pump.
Paki korek na lang po
January 11th, 2005 04:26 PM #4so di na kailangan yung balancer oil seal and oil pump?
Sorry not much of a help.
January 11th, 2005 05:28 PM #5
Originally Posted by artpogi
we'll also wait for other feedbacks.
thanks!
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 12th, 2005 11:07 AM #6oil pump minsan lang nasisira. no need to replace that pa siguro.
if you need prices for the rest try calling the shop and look for toto.
January 12th, 2005 04:04 PM #8
pre, ask ko lang, anu ba yung mga 7g or 7g+sumthing? if ever auto ko is 96 galang VR V6? anu naman yun, explain naman tnx
January 12th, 2005 04:13 PM #9
7G = 7th generation of Galant, yung Galant mo is a 7th generation.
the Galant GTI belongs to the 6th generation hence 6g.
yung pinaka latest (well at least locally) is the 8th generation Galant
Someone korek me please.
January 12th, 2005 04:30 PM #10
shark ones belong to the 8th gen. while the rayban tail light to the 7th gen.
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
