Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Aug 2006
    Hello mga fellow tsikoters..
    Last 2 weeks ako nag pa overhaul ako ng carborator ko then palit air filter, sparkplug and fuel filter nadin..
    after matapos na lahat ok na..then pag uwi ko then overnight parking, kinabukasan pag bukas ko ng door ng otobot ko...amoy gas...
    hinde ko naman alam kung pano nangyari nun..
    may feeling ako na baka sa fuel filter yung may tagas???
    any feedback will be greatly appreciated...pano ko kaya matatangal yung amoy..
    kakahilo kasi eh..
    Thanks for reading these..
    Sep 2006
    Check under the hood. Most likely may leak yan somewhere within the engine bay itself ..
    Aug 2004
    Baka may na-spill ng gas sa pagpalit ng fuel filter. If the smell doesn't go away, check for fresh leaks and re-tighten the hoses, as necessary.
    Nov 2006
    ...check your charcoal canister.
    Jul 2006
    Check kung malinis pagkagawa sa repairs. If not, correct this problem. Clean the surrounding areas first, avoid driving the car baka may fuel leak and the heat from the engine will cause a fire to start.
    Aug 2006
    check the fuel line o
    singit po ako mga boss, sa akin naman po, sa may front passenger side na wheel well, sa may engine, amoy gas pagkatapos magdrive, pagpark usually amoy gasolina po. sa driver side naman po wala naman. normal po ba yun? ano po kaya problema? TIA!
    Apr 2005
    Quote Originally Posted by d j View Post
    ano yung charcoal canister boss??? san makikita yun?
    Jan 2003
    Note that your post would do more harm than good.
    Quote Originally Posted by CaMoTe!!! View Post
    baka si DJ meron charcoal canister sa loob ng car pampaalis ng amoy..
Amoy Gas sa loob ng kotse
