Results 21 to 30 of 34
January 10th, 2005 06:42 PM #21
di ko rin alam eh.... basta nagpapalit lang ako every 3 months nung ordinary pag nag pa tune up ako. pag di ko pinalitan di maganda yung takbo kahit linisin mo. yung splitfire nililinis lang ok na
January 10th, 2005 07:20 PM #22
Sulit Torquemaster. Used it in our terrano from day one till day sold.
- Oct 2004
- 138
January 26th, 2005 03:54 PM #23Originally Posted by speedyfix
my 2 cents.
- Nov 2003
- 98
January 27th, 2005 07:54 PM #25
ang denso iridium spark plug (single tip) hindi ko alam bakit ang mahal 600/pc pero same lang din naman every 20K km pinapalitan...
samantalang yung denso na ordinary 300 lang ata ang set of 4 na tapos every 15K papalitan... oh well.
hindi na ako nagpakabit ng iridium
January 27th, 2005 08:15 PM #26
yes guys anong tamang paglinis ang spark plug
sa akin bosch platinum
Tsikot Member Rank 5
- Nov 2003
- 3,848
February 10th, 2005 12:11 PM #27just have the mechanic clean the plug for you. you might damage the tip pa if you don't do it properly.
iridiums really are meant for higher performance engines. they can sustain the spark despite high cylinder pressure kasi without being snuffed out.
if plugs get fouled soon that means there is something wrong with the air fuel mixture.
February 10th, 2005 12:15 PM #28
if sobrang dami at wala ka nang malagyan ng pera mo, denso iridium. pag hindi normal oem plugs
February 11th, 2005 02:32 PM #29
i've been using those NGK types before ever since we got this corolla but when i tried on the Bosch Platinum 4 mas bumilis ang hatak ng tsikot ko.. syempre nagpalit din ako ng high tension wires para hindi sunugin ng spark plugs diba.. pero the thing is there is definitely a change in terms of performance.. my engine is stock with an open carb
February 11th, 2005 02:55 PM #30
Like what Miggs pointed out, it's basic physics, least resistance, period. Unless your sparkplug has multiple spark tips (not the conductor tip), iisa lang labasan ng kuryente. Your "electric bolt" will not split into two if you use a V tip, it will not split into 4 if you use a 4tip, it goes to the ONE with the least resistance.
Mas lumalaki ngang chance mag misfire if you have multiple conducting tips since the current won't go straight to a designated tip eh, maghahanap pa yun between the "choices" that are available..
Gains on a stock engine? One word... PLACEBO.
Any reviews for the Triton GLX 4WD 6MT? Siya ata pinakasulit na middle 4WD variant. Price range...
2022 Mitsubishi Strada/Triton (6th Generation)
