Results 1 to 9 of 9
November 30th, 2006 03:30 AM #1
mga peeps, tanong ko lang. Nakakuha ako ng 2 ton jack for dirt cheap. Wondering if that is enough (weight and height) para i lift and 97 civic para mapalitan tires and oil change. thanks.
BANNED BANNED BANNED
- 3,790
November 30th, 2006 03:39 AM #2oo naman...less than 2 tons lang ang cars and pick-up. kung mga nkr, canter .... hindi na pede yan.
dapat bumili ka rin ng jack-stand...most lift jack can lift but not hold on that lift...so pagkalift mo, salpakan mo ng jack-stand
November 30th, 2006 03:49 AM #3
November 30th, 2006 04:51 AM #4
A 2 ton jack will work, but know that the only thing that holds the car up are some O rings inside the piston and enough pressure to keep it steady. Get a good set of 2 ton jackstands and place them on the jackpoints (use wood if necessary) to relieve stress on the jack.
Of course, provided your Civic is near empty with luggage. This makes it much easier too.
November 30th, 2006 07:55 AM #5
Awesome. Will buy jack stands talaga, better safe than sorry. I was just reading someplace na yung guy ginamit 2ton jack but nasa limit na daw yung jack and hindi pa umaangat yung gulong sa ground. although Could be a blown suspension daw. I just wasnt sure kung limit na yung 2ton para sa civic. ayaw ko lang bumagsak kaagad pag akyat. hehe.
Zombie
- Aug 2006
- 728
November 30th, 2006 09:20 AM #7
kaya ako minsan nag dadala ng block of woods ,pag mejo malayo ang pupuntahan at may mabigat na kargada.para pwede pang tukod at pang kalso sa Gulong na din
November 30th, 2006 10:52 AM #8
2 tons is roughly 4,000 lbs. already.
But yes, use jackstands. Nasa Php750.00 dati sa SM (KYK Brand).
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
