Results 1 to 13 of 13
    Jun 2009
    Mga Sir!
    Nung tuesday, mag start ng sentra ko. So dinala ko sa mechanic ko, tinow namin. Sabi sakin, sira daw computer box and igniter. Ayos na daw igniter. Computer box na lang.
    Nagtry daw sya ng ibang computer, nagstart daw. Try pa daw kung kaya repair.
    Sa pagkakaalam ko, mahal ang computer box. If ever po na kailangan na palitan, nasa magkano po kaya aabutin? Di pa po nagbibigay ng estimate kasi nga try pa kung kaya ma repair.
    Thank You!
    May 2009
    Quote Originally Posted by loki_chaos View Post
    Mga Sir!
    Thank You!
    computer box din sira nung series 4 sentra ko. naka ikot na ako sa evang at banawe. presyuhan nila surplus 14k pataas. pag brand new mga 60k daw. sana ma repair din yung computer box ko.
    I got a ECU for a GA16DNE B14 for 8K two years ago from Rick Lim's Surplus (lumipat na siya somewhere else though and i don't know kung saan na).
    Jun 2009
    yun nga sir, 8k lang talaga bentahan ng surplus ECU, inabuso lang talaga kasi mataas ang demand... magkaiba ata tayo ng engine
    sir, ga16 sakin eh...
    Feb 2006
    What is the P/N of your ECU? I have new stock arriving in a couple of days. Will be pricing them cheaper than Banawe shops para makatulong na rin sa mga nabahaan na Tsikoteers.
    Jun 2009
    sir, eto po yung part number...MEC-N101B B1 7Z10... if ever po, how much are you going to sell it? brand new po ba or surplus?
    Jun 2009
    Good day!
    Would you have one for a 96 Sentra 1.6SS Manual (P/N 23710 2M305 / MEC-N101 C24Y04)?
    Thanks in advance
    Quote Originally Posted by gschan View Post
    Jun 2009
    Hello Sir
    dumating na po ba stocks ninyo?
    Thanks!
    Mar 2007
    Another alternative for an original ECU...
    If you are as practical as some people - they would consider this - local ECU alternative conversion. PINOY MEGA SQUIRT.
    More about it in this site.
    pinoymegasquirt. blogspot. com.
    Recently, we were able to make a 94 Montero V6 - run. It was a bit hard since it was a flooded car, no ECU to be found anywhere. The owner decided we convert it with PMS VEMS.
    Not only is it running again... it can also be tuned to your preferred running trait. If you want Economy or Racing or both. Check out the site.
    Installation within 1 day. More or less 8 manhours, provided all items needed are at hand and no electrical issues to deal with like shorted or grounded starters or alternators.
    Cheers.
    ^^pwede rin convert na lang sa LPG para wala nang sakit ng ulo.
    Kadalasan naman na nakausap ko na nagpa convert ng LPG kadalasan problema nila ay tagas ng langis sa valve cover gasket at mga oil seal dahil pag LPG raw ay masyadong mainit ang makina.
    Quote Originally Posted by speed unlimited View Post
    Kindly refer to the following discussion thread for better information about Auto-LPG from actual users:
    Auto-LPG Conversion Thread:
    http://tsikot.yehey.com/forums/showthread.php?t=29208
    Mar 2007
    First run of "Storm Ondoy" devastated Mitsu Montero '94 6G72 running and idling smoothly with the latest Alpha_303q burned into my self built MS2 daughtercard and Custom Designed PCB routed Megasquirt with provisions for Peter Florance's sequential injections!!! idling stepper motor is totally busted modified it to used a printer stepper and it worked and way better than that of the stock Stepper!!! Can't find a replacement for the busted Distributor so Modified the Dizzy to used a fiber-optic tru-hole sensor and it worked perfectly!!!
    [ame="http://www.youtube.com/watch?v=q10_m1O2jj0"]YouTube- MONTERO.3gp[/ame]
1999 Sentra Computer Box and Igniter
