Results 1 to 16 of 16
    Jul 2004
    I called my service adivsor to have my escape scheduled for the 1000km checkup and asked what they were gonna do with the vehicle. He said that they would only be tightening the bolts, period. Thats it???? What happened to the Change oil ???
    They said that the Japanese cars are the only ones who needs to change oil on the first 1000kms. BS!
    Tell me they are wrong!
    that's more or less the norm now... no oil change at 1000 km. kaya usually free yung 1,000 km service, kasi puro inspections lang yung gagawin.
    if it uses fully-synthetic oil, the first oil change is usually scheduled at 10,000 km or 6 months
    ganyan yung schedule ng cr-v, rav4, etc...
    Kung gusto mo gumastos pwede din..almost P3,000 ung chang oil nyan.
    Jul 2004
    darn. iba na pala ngayon. its been awhile since ive bought a brand new unit na kasi. Dati kasi, 1st 1000kms eh may change oil na libre.
    Would you guys recommend that i change the oil sa 1000km checkup ko? or should i wait for the 5000km checkup? I thnk ang gamit nilang oil is yung shell oil na normal lang.
    Check the owners manual... it should be mentioned there. Its something already with the newer cars now (not all though)... but i still dont feel comfy with it as i've gotten used to the 1K change oil when brand new.
    dapat siguro talaga i change oil kasi yun mga contaminants sa engine mo dapat matangal....
    kahit ako.. di rin comfortable
    pero ako bago pa lang ang ride... walang breakin breakin 100kph kaagad... tukod..
    kasi the reason on this is dapat masanay ang engine mo sa sa takbo na yan.. kungid sakal.. especially for the DIESEL Engine.. pero siyempre kanya kanya yan...
    Jul 2004
    by 1000kms ba, matatangal na yung mga "contaminants" sa engine? baka naman ginawa nilang 5000kms kasi hindi pa matatangal lahat ng contaminants by 1000kms?
    Jan 1970
    In my opinion the Ford adviser is right.
    Hindi ako nagpachange oil sa first 1000km ko din sa escape. The reason is, the factory uses a special oil on brand new units that is designed for engines that have not yet developed wear marks on its cylinders.
    After around 5,000 kms, pwede mo na palitan (and dapat mo nang palitan) nang regular oil. I use Caltex Havoline energy 5W30 semisynthetic dahil wala akong mahanap na 5W20 oil.
  9. #9
    Di ba masyado malabnaw yung 5W20 in a tropical country?
    Jul 2004
    They use a special oil? I just called and re-confirmed from Ford Alabang and spoke with their technical department and they said that the oil they use for ford vehicles are the plain Shell Motor Oil. (5W30) - the regular one - (color yellow casing). They dont use any special oil.
    Jan 1970
    The dealer syempre uses plain over the counter oil for periodic oil changes.
    The manufacturer uses the special oil (yung initial oil na nakalagay sa machine).
    Jan 1970
    Medyo nga, kaya siguro wala akong mahanap na ganyan.
    Yung ginagamit ko na lang is 5W30 na Caltex energy saving oil, helps a bit sa fuel economy ko specially now that gas prices are over the top.
    Jul 2004
    you are right. i talked with Van Anesato of Ford Philippines (cavite plant) and he said that they use s special blend oil which thet have shell make which removes the deposits during the break-in period. He advises to change oil on the 5000km checkup instead of the 1000km as he said that 1000kms still isnt enough to remove all the quirks. FYI.
    If you want to talk to him, their tel# is 049-5415000
    medyo malabo ata yan ah...
    any deposits, grime or what not should be trapped in the oil filter, the oil should be clean regardless of mileage if the filter is doing its job.
    Apr 2004
    sa manual parin ako maniniwala..
    karamihan sa mga dealers kasi harang na sumingil, walang malasakit mga service staff sa kanilang clients..
    malaking investment din magkaroon ng sasakyan..kaya dapat lang ingatan sa maintenance.
    Jun 2004
    yun ata dahilan kaya di advisable to use fully synthetic in break in period..>>
1000km checkup... No change oil ?!?!?!
