Results 1 to 3 of 3
    Jul 2011
    I would like to seek some helpful advise with regards to the Alternator warning light when the ignition is initially switched on and go out when the engine is started.
    Is it normal or it has some problem with the battery, alternator, or electrical wiring? Does this alternator warning lights should always comes out regularly when the ignition is switched on and go out when the engine started? Does this scenario shows that when the ignition is on the battery is not charging (alternator warning lights is on) and when the engine started the battery is charging (alternator warning lights is off)?
    Your immediate response is highly appreciated. Thanks..
    my car is 1998 Daewoo Espero.
    as long as namamtay at hinde na umiilaw ulit, normal lang..
    Quote Originally Posted by mark_morin View Post
    It's normal.
Help! Alternator warning light is on?
