Results 1 to 10 of 17
March 11th, 2010 07:02 PM #1
hi guys,
need help with our nissan sentra series 3 super saloon 96 model.
nabiktima ni ondoy.. right after namin mapa andar, meron ng sound pa apak sa clutch parang whistling sound. ano po kayo problem dito? meron na po ba naka experience neto?
thanks
March 12th, 2010 05:49 AM #2
Do you hear it when depressing the clutch pedal? Its the release bearing.
March 12th, 2010 09:53 AM #3
March 12th, 2010 10:43 AM #4
March 12th, 2010 01:11 PM #5
ah ok.. delikado po ba na patagalin to or need na talagang palitan?
mga sir, magkano kaya abutin to? estimate lng po para may idea lng ako.. and kung meron po kayo recommended na shop.
- 99
March 12th, 2010 01:24 PM #7
March 12th, 2010 04:25 PM #8
Maingay yan tsaka pwede rin sya mag stuck up hindi na iikot yung clutch.
Estimate:
Labor: 1500
Release Bearing: 350
Clutch Disk: 800
Pressure Plate (if applicable): 1800
You may want to change your oil seals as well.
Rear Oil seal (behind the flywheel)
Differential Oil Seal (left and right)
Striking rod oil seal
etc.
Humigit kumulang malaki ang gagastosin mo talaga.
Where are you from?
March 12th, 2010 05:07 PM #9
dto ako banda Q.C. sir... most likely banaue ang magiging prospect ko para sa mga to.
although i don't know any shops there that can be trusted there for this kind of work... marami kc dun sabi ng sabi na kayang kaya nila then at the end nangangapa lang pala sila.
any recommended shops bago ako makipag sapalaran sa banaue.
March 12th, 2010 05:12 PM #10
