Results 1 to 3 of 3
    Good day mga chiefs
    Hihingi lang po sana ako ng mga opinon at suggestions nyo regarding my problem. I'll try to keep it short and concise para hindi sobrang haba basahin.
    I drive a 97 model sentra series 3 (tho 2001 lang nabili sa casa) and here are my problems:
    1.) New SPRINGS - nakuha ko na sya lowered at pinaputulang na yung mga springs so plan kong palitan silang lahat ng bagong springs. Ok pa daw yung mga shocks at hindi pa kailngan palitan sabi ng mekaniko.
    -- Ano ba ang mas ideal - original or replacement springs lang? may difference ba?
    -- Will installing new stock springs greatly improve the ride comfort ng auto ko at mababawasan yung tagtag nya? or is it just a waste of time and money?
    -- Any particular brand of springs that you could recommend?
    2.) Kumakadyot when shifting in lower-middle gears (1st-3rd) unless apakan mo ulit ng konti yung clutch then release ulit pagtapak sa gas.
    -- Sabi ng mekaniko na malinis pa yung "throttle body" so baka daw ung "servo" na ang kailngan linisin tho medyo sesitive daw linisan un kaya medyo matatagalan syang gawin.
    -- Any suggestions or inputs on this?
    3.) Rattling sound coming somwhere from the dashboard pagnaka-on ang AC habang tumatakbo, tho minsan nawa-wala-wala din. Pero mas malakas sya pag pa-akyat yung auto at nasa 1st gear ka.
    -- Sa AC kaya ito? or dun sa AC Vents? auxillary fan kaya kase sabay sialng umaandar ng AC?
    Pasenya na po at parang mahaba pa rin ang post ko, gusto ko lang talaga makakuha ng mga insightful feedbacks at inputs nyo po mga chiefs.
    Maraming maraming salamat ulit sa inyong lahat.
    Cheers!
    Dec 2009
    1. its better to go stock kung ayaw mu ng tagtag sa ride mo. engineered ang suspension natin ng mga taga nissan so might as well just let them be and not mess with it.
    better the oem springs. I can't recommend any brands kasi stock lang rin yung akin so i guess nissan springs would be the best.
    2. walang servo ang engine natin (kung super saloon ka) kung ex saloon naman efi na rin yan. so IACV_AAC Valve is generally easy to clean you can do-it-yourself if you want to clean it. May steps sa sentraclub.ph kung paano gawin iyon. yung sa kadyot naman more or less mali lang yung timpla ng clutch saka gas.
    3. yung sa rattling dashboard hinahanap ko rin yung ganyan ng sa akin tumutunog lang rin sya kapag nakabukas ang a/c feeling ko nasa evaporator box sya, sa cooling fan, or sa air recirculator. Baka may loose na, hindi ko pa gaano na inspect yung akin eh. Mainit kasi sobra. hehehe
    hope it helped! Happy motoring!
    Quote Originally Posted by kurby View Post
    Thank you very much chief sa iyong mga input. Bale super touring yung sakin and yes EFI na engine nya so I'm not so sure kung parehas nga ng engine ng super saloon na wala ngang "servo", tho hindi rin ako sigurado. Psensya na, wala kase akong masyadong alam sa makina at sabi lang sakin nung mekaniko na baka nga yun ang problema pero hindi pa talaga nya tinitignan ng husto. I'll check yung sa sentraclub.ph.
    Regarding the springs, yep nakakainis na rin kase na ramdam na ramdam namin lagi yung daan kahit maliit na lubak lang kaya gusto kong ibalik yung dati nyang taas and have new stock springs installed sana. Magkano ba mga OEM springs ngayon?
    Yung rattling sound sa tingin ko maaring galing sa mga maluluwag na bearings sa loob ng AC. That is kung meron nga nito.
    Thanks ulit sa input mo chief. Malaking tulong talaga sakin so please post more inputs lang kung meron pa kayo.
    Salamat ng marami
SPRING questions and RATTLING dashboards - HELP
